E21 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > E21 (1975 - 1983)
E21 (1975 - 1983)
Old 12-17-2019, 05:01 PM
aamerift2019 aamerift2019 is offline
Mein Auto:
E21
I own a 1982 BMW 320i 5 speed manual and my mechanic replaced few seals in the transmission as there was a little leak. After he buttoned up everything the transmission would not come out of 2nd gear. Any ideas??
Old 12-17-2019, 08:14 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x3,E30x2, F150
Welcome to Bimmerfest!
He didn't crank in on the shifter detent spring plunger, did he?
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe "; 1985 325e "Hazel Ann"
Old 12-17-2019, 08:30 PM
Mein Auto:
I do not know. I was not there.
Old 12-17-2019, 09:40 PM
D'oh, You Kids!
If the detent ball is forced into the shifter shaft hard enough it becomes impossible to change gears. That can happen if the plug that has a shoulder is inadvertently swapped for a plain plug that will screw in too far.
Name:	E21 shift.png
Quotes to live by:
BMW-CCA #441426
Old 12-18-2019, 01:06 AM
Mein Auto:
Thanks.
The technician is looking into this now and hopefully he can resolve it. Looks like exactly what you described happened in my case.
Old 12-18-2019, 10:56 AM
Mein Auto:
They again have to open the back end of the transmission to see what is going on.
They removed the back end to replace the seals and it stopped shifting after they put everything back together. They still do not know the cause
Old 12-18-2019, 12:54 PM
D'oh, You Kids!
Weird. Obviously something's not put together correctly. Wish I could be more help.
Quotes to live by:
BMW-CCA #441426
Old 12-19-2019, 11:49 PM
Mein Auto:
Without removing anything they were able to fix the issue. They drove the car in 2nd gear and the transmission started working. This is what they told me. They drive the car for an hour and all gears shift fine.
Old 12-20-2019, 08:44 AM
D'oh, You Kids!
I hope it's really fixed, because that sounds extremely fishy. As long as it works now and wasn't damaged, that's good news.
Quotes to live by:
BMW-CCA #441426
