Weird cold shift point --> normal? - Bimmerfest - BMW Forums
Old 01-08-2020, 02:52 PM
robinasu robinasu is offline
Mein Auto: M5
Hey all, since I bought the car some months ago, when cold, the 2nd to 3rd shift point is kind of high- about 2.5k. When warm, it shifts "normally," depending on load.
It seems harmless, but has always been odd to me.
Does this happen with your vehicles? I'm driving a 2012 X5d.
Old 01-08-2020, 03:06 PM
Chill_X5 Chill_X5 is offline
Mein Auto: 2012 X5d
I have 2012 X5d and I do have the same thing happening. I"ve been told it's normal for diesels to do so. Car wants to warm up as quick as possible.
Old 01-08-2020, 03:31 PM
Doug Huffman's Avatar
Nuclear engineer
Yes. Certainly the 35d delays first and maybe second shift to warm the ZF and engine. I'll see if I can find the citation ... nope, didn't find it.
Old 01-08-2020, 03:55 PM
Mein Auto: M5
Cool
Thanks - makes sense they want it hot, but then they use a **** thermostat with ****ty or no ecu logic to detect a thermostat failure.
Old 01-14-2020, 09:59 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
Yes it revs high when cold but you can get xhp and flash a tune that doesn't do that
FYI: I can't see your signature because I turned off that option since people like to put big images in theirs, which this site doesn't let you block...
Old 01-15-2020, 07:55 AM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
Does that to lower NOx emissions. Diesels are not as quick to warm up as gasoline engines.
Old 01-15-2020, 10:39 AM
QSilver7's Avatar
Mein Auto: 2006 X5 4.4/2013 650ix GC
Its an engine warm up cycle:
Another way to get out of this cycle...if you have the M/S Steptronic set-up...if you push the gear selector over into the S (sport) gate...this will stop the "adaptive" funcitons of the transmission thus stopping the engine warm up cycle's programming. Once you've reached any of the requirements for ending the warm-up cycle (the speed limit is usually the 1st or easiest to acheive)...you can then push the gear select lever back into D to resume regular shift patterns.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 01-15-2020, 02:02 PM
2010xdrive35d's Avatar
2010xdrive35d 2010xdrive35d is offline
Mein Auto: 2010 X5 xdrive35d White
Happens to me too! Letting the d run a little longer in the mornings before take off makes it shift sooner. Still thinking when I do my trans service that might smooth out. Won't know until then.
Old 01-16-2020, 06:42 AM
What's funny about that "official documentation" is that it still will shift high... I got rid of the stupid behavior by using xhp.
Also higher rpm when cold does not help a diesel warm up... More cold air means a colder burn.
Old 01-16-2020, 06:53 AM
Nyc Dito's Avatar
Nyc Dito Nyc Dito is online now
Kinda officially welcomed
Mein Auto: E70 LCI 35d
Q,It didnt work for me. Sport mode acted the same when cold yesterday and today (except obviously sporty once warmed up). All good though, im doing XHP/Rod Sutphin soon.
E70 LCI 35d
E90 LCI 328i xDrive
E39 528i/5 Sport
E28 535is
E84 X1 35ix M package
E38 740i Sport
E39 M5 LMB/Blk
Old 01-17-2020, 04:23 PM
Mein Auto: M5
I was interested until saw I need to buy another app and android phone to load it. Maybe I will get interested later. Please let me know is this is incorrect.
