Intermittent windshield washer fluid leak - Bimmerfest - BMW Forums
Old 01-20-2020, 05:46 AM
Danno123 Danno123 is online now
Mein Auto: 2011 X5 (N55)
This is a weird one. I've noticed that I use a lot of windshield washer fluid and have suspected for a few months that there's a leak. Yesterday, I put about half a gallon of fluid in and the washers worked fine while I drove a couple hours on the highway. I drove the car this morning and parked it in the garage. A few minutes later, I went out to the garage and could hear fluid leaking from near the reservoir. I put a cup down under the car and, sure enough, it was streaming blue washer fluid. The thing is, however, the leak appears to be intermittent because it wasn't streaming fluid out yesterday or it would have emptied the reservoir in about 5 minutes at the rate it was leaking. I believe the most common points of failure are the gaskets that hold the pumps in place. But I don't know why a gasket would hold for 24 hours and then all of a sudden start to leak. Any ideas? Also, does anyone who has done this job have any pointers?
Now that I think about it, I suppose it could have been coolant, which is also blue. But I heard it leaking from near the washer reservoir. I'll check coolant level just to make sure.
Old 01-20-2020, 05:50 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Dab a finger and taste the fluid. WW fluid has alcohol as antifreeze. Coolant has sweetish tasting glycol as antifreeze. A taste of neither will harm you.
Old 01-20-2020, 10:32 AM
FredoinSF FredoinSF is online now
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Not sure if this would apply to the E70 but on the E46 the pump is at bottom of tank and with age the o ring fails and you get a leak. Happened on my E46 at 11 years of age. Was my first repair on that car.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 01-20-2020, 11:02 AM
Nuclear engineer
The pumps on all BMW WW reservoirs are on the bottom to provide Net Positive Suction Head for efficient pump operation without priming.
Old 01-21-2020, 06:59 AM
1bad540's Avatar
1bad540 1bad540 is online now
Mein Auto: E65 750i Sport,C5 z51 e46
My e46 currently doesnt hold any fluid either. need to address when warmer!
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,20"s63rims
e70 3.5 aw.mtec,20" 214 whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
w222 S550 amg, dia white
Old 01-21-2020, 09:31 AM
DEADF15H DEADF15H is offline
Mein Auto: 01 325i sedan 261,602 mi
Having the same issue. I'm going to to pull mine and have a look. Not as easy a job as it was on my E46. I think you have to remove the fender liner to get to it. Was going to to replace the seals first, before buying a pump, unless I can tell it's obvious the pump is the culprit.
Sent from my SAMSUNG-SM-N910A using Tapatalk
01 325i Auto 265,000 Miles
07 E70 3.0si 170,000 Miles
Old 01-21-2020, 09:39 AM
twh twh is online now
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Yea, on the X5, it is a bit of a PITA to get to the pump. You have to hack out the one-time-use plastic rivets holding the fender liner in place. Then you have to reach your hand in there -- the fender is flexible, so don't worry about that. Replacing the fender rivets, you'll need a rivet install tool that handles that diameter of pop-rivet.
Old 01-21-2020, 12:04 PM
Masoe Masoe is offline
Mein Auto: 2012 750Li/2008 X5 4.8
Please check out this link..hope it helps. https://www.bimmerfest.com/forums/sh...dshield+washer (fix starts at post #24) good luck.
BTW, i got the Pop rivets and Gun from Harbor Freight for about $17 bucks (https://www.harborfreight.com/hand-r...ets-97757.html)
2012 750Li, Carbon Black Metallic/Oyster&Black, M Sport (Current)
2008 X5 4.8 (Sport), Platinum Bronze Metallic/Tobacco&Black (Current)
2006 750i, Sapphire Black Metallic/Black
2002 745i, Sapphire Black Metallic/Beige
2002 530i (5 speed), Sapphire Black Metallic/Black
Old 01-21-2020, 12:13 PM
That looks like the one I have although I didn't get it at Harbor Freight.
Old 01-23-2020, 06:54 AM
Thanks for the link to the Harbor Freight pop rivets and gun. I'll pick one up. Unfortunately, I'm in Michigan and have an unheated garage. I hate working on the car in the winter because plastic pieces get so brittle. BTW, for those thinking about tackling this job, I've found two online resources:
https://www.newtis.info/tisv2/a/en/e70-x5-xdrive35i-sav/repair-manuals/61-general-vehicle-electrical-system/61-67-headlight-cleaning-system/OHQvske
Old 01-24-2020, 01:34 AM
sirox101 sirox101 is offline
Mein Auto: 2007 x5 3.0d
i also had a bad leak on my e70 turned out to be the line had a break in running to the rear washer leaking in drivers footwell , i disconnected the rear line until i get time to lift out the carpet and trim to find leak
Sent from my iPhone using Bimmerfest
