signs of F30 N20/N26 timing chain issue, and OCI to the rescue? - Page 9 - Bimmerfest - BMW Forums
Old 01-17-2020, 10:53 PM
Folgen Sie Mir's Avatar
Folgen Sie Mir Folgen Sie Mir is offline
Mein Auto: Fast
I weigh 180 & drive the xdrive....if someone drives a RWD and they weigh 400lbs will it break the TC due to stress induced by the extra weight?
Old 01-18-2020, 01:34 AM
namelessman namelessman is offline
Mein Auto: bimmer
Great question, 2 passengers of 200lb do add 400lb on RWD/xDrive.
One simple observation is that, based on the failures, some N20/N26 TC + guard rails are exerted out of spec.
What is BMW's spec on N20/N26 TC + guard rails?
In that design spec, what is max weight, max lb-ft, HP, lowest engine oil viscosity, max OCI, ASS operating frequency, TC accelerate/decelerate angular torque(?), stress parameters of plastic parts and metal links, etc, etc, etc?
What parameters are missing from BMW's system simulation of this design? What margins were built in to the design/simulation, e.g., 100%, 200%, 500%?
Without BMW disclosing its findings, all that owners can do are to speculate and formulate best guesses based on anecdotal experience from affected owners and empirical observations from shops/dealers.
Old 01-18-2020, 10:51 AM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
[QUOTE=namelessman;13222885]From an engineering perspective the root cause probably was determined long ago, and failure % computed with extreme precision.
[QUOTE]
In the meantime, another fellow N26(with PZEV warranty) owner at work plans to not bring car to dealer until CEL, even if engine whines crazy.
His rationale is that if CEL is not on, BMW will not pay for repair. But when engine blows(or is close to blow) due to TC jumping teeth, CEL will almost be inevitable(at least that's theory).
So just wait for the magic CEL, and make BMW pay for engine replacement.
This is not my preferred strategy, but it sounds logical.
[UNQUOTE]
I assume you are friendly with your co-worker. If so, please knock some sense in to him; BMW will indeed pay for new TC based on an audio recording of the whine noise matching a file they already have. I assume he is within extended warranty limitations.
Most failures happen this way: plastic bits from TC guide block the oil pump intake, low oil pressure, iDrive warning message and engine shutdown - all within a minute or so. During this minute or so, the timing goes out of wack and a piston touches a valve. That will be $14k for a new motor, Sir.
"Friends don't let friends wait for the CEL" - it may never go on.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 01-18-2020, 03:13 PM
DadzBmerN20 DadzBmerN20 is offline
Mein Auto: 2013 320xi
I thought i saw somewhere can't remember if it was off the YT channel of ThicF30, but certain years before 02/13' and older might have that bad design. Honestly i asked my BMW Service Advisor about this and he said it sometimes makes a distinct noises and if you want the diagnostic it would cost like a $100+ or so, i said never mind and mine was made in 06/13 lol. And i only have currently 43k miles on it, barely use it...
2013 320i x-drive sedan
Bootmod3 Stage 1
20% 3M tinting front & back
Res + Muffler Delete w/Magnaflow Tip
HPB LED DRL's Amber
Old 01-18-2020, 09:15 PM
Mein Auto: bimmer
His N26 should be a 2014 with 80k+, so his car is out of 7 years/70000 miles ELW.
However CA and oher PZEV states still offer 15 years/150000 miles emission warranty, and that needs a CEL to trigger TC coverage.
Old 01-19-2020, 07:09 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2016 320i
Originally Posted by namelessman View Post
Yes there is a new part# starting 1/2015. The assumption is that F30 built after 1/2015 will get revised chain
Do note there is no formal acknowledgement from BMWNA of this issue, even though anecdotal comments from foreman and tech indicate otherwise.
my 320 4 cycl 9/15 production date has the orange chain guides at 18k miles
surely goodness and mercy will follow us all the days of our lives
2016 320 f30
2011 328IX
Old 01-19-2020, 07:55 PM
backpackerx backpackerx is offline
Mein Auto: 2013 328ix
Mine was whining pretty loud but when they replaced everything they said the plastic guide was not broken but the timing chain was definitely stretched. XDrive 68,500 mi.
Old 01-19-2020, 08:12 PM
Mein Auto: bimmer
The white color plastic guide does turn brown/orange in color after some heat cycles.
Old 01-19-2020, 08:15 PM
Mein Auto: bimmer
Did your dealer offer any explanation of the failure?
Old 01-19-2020, 09:20 PM
No, they just diagnosed it as a stretched timing chain and replaced it, the guides, the tensioner, and the oil chain. I specifically asked the service advisor if they found any plastic because I was worried about it getting in the oil pick up and he said no.
Old 01-19-2020, 10:04 PM
TopQuark TopQuark is offline
Mein Auto: BMW 528i
Good input. Iím going to replace my timing chain tensioner to the 2016 version. It doubles the amount of spring force and has a larger hole for oil passage. Hopefully this will increase its life span despite the stretched timing chain.
There were mixed messages that the oil pump chain is the real culprit but doesnít seem to be the case.
My warranty ends this month and I only have 42k miles on a 2013 model.
Old 01-19-2020, 10:11 PM
Mein Auto: bimmer
Is there a link to any spec that says new tensioner has 2x amount of spring force?
Old 01-20-2020, 08:41 AM
DBU's Avatar
DBU DBU is offline
I am not aware of such a link. But when I changed my tensioner, I noticed the spring on the new one being much harder to depress. And yes, the hole for the oil inlet is obviously larger. Check out the pictures in my DIY, which I have posted several times under various threads re. TC issue.
Old 01-20-2020, 01:02 PM
Mein Auto: bimmer
My strategy(and per foreman's suggestion) is to not touch it until settlement conferences are over. Once the settlement(or lack of and subsequent trial) outcome gets clear, then the next step will be evaluated.
As of right now, my TC and guard rail cold this morning still does not have slack, so the factory original tensioner seems to be still OK.
Old 01-20-2020, 04:13 PM
vkat87 vkat87 is offline
Mein Auto: 2014 328i xDrive Sport
Are you tugging on the TC underneath the oil cap to check for slack? How are you checking the guard rail?
Old 01-20-2020, 05:41 PM
Mein Auto: bimmer
Yes just open the oil cap and then reach in and move TC + guard rail around to test for play(both parts have no play/slag on mine),
Old 01-20-2020, 10:52 PM
Mein Auto: BMW 528i
Here you go. Not exactly 2x. More like 1.6x. The tensioner is the same part as for n20:
Old 01-20-2020, 10:58 PM
Mein Auto: BMW 528i
The chain could have a large slack or none at all when the engine is not running. The rod in the tensioner pushes out only when the engine is running as oil pressure increases.
Try cranking the engine. At some point, the chain seems loose but that is normal.
Old 01-20-2020, 11:34 PM
Mein Auto: bimmer
My understanding is that the spring keeps TC snug when engine off, and the oil pressure takes over when engine on and oil pump on, right?
When engine on, there should be no TC slack or else there will be high pitch whine.
Local foreman did check my TC three month ago, and he just stuck finger through oil cap opening after engine off, and confrimed no TC nor guard rail movement while hot.
Old 01-21-2020, 09:26 AM
Mein Auto: bimmer
Great video. It probably is a good idea to swap in even with no TC issue.
Old 01-21-2020, 10:38 AM
Our BMW Our BMW is offline
Mein Auto: 328xi GT
The music on the video sounds like an 80s porno. Not that I've ever watched one.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to slide in sideways, totally worn out, shouting "Holy ****, what a ride!"
Old 01-21-2020, 04:51 PM
Mein Auto: BMW 528i
That's correct. Also snug when engine is hot. Oftentimes, the cam lobes can be in a position that make it loose too. Futher discussions here:
https://f30.bimmerpost.com/forums/sh...4&postcount=11
Old 01-21-2020, 06:31 PM
Mein Auto: bimmer
Wow that thread says(quoting a BMW field engineer?):
"The n20 engine when the cam lobes come to a rest vertically to the valves (very rare instance) they will rotate back slightly and cause slack in the chain"
Can this very rare instance be missing from BMW's system simulation, and hence lead to real-life timing chain failure?!?
Old 01-24-2020, 11:53 AM
FredoinSF FredoinSF is online now
Anyone have info on part cost and labor hours involved in doing a preventive timing chain job?
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
Old 01-24-2020, 01:18 PM
JoeyMcMahon666 JoeyMcMahon666 is offline
Mein Auto: 2004 BMW 530i e60 5 serie
2700-3500. xDrive would be closer to the 3500 from the quotes I received.
