All BMWs Trimmed CAFD - Bimmerfest - BMW Forums
Old 08-18-2018, 09:20 AM
babyk babyk is offline
Mein Auto: BMW F30
Trimmed CAFD
Hello
Anyone know how to get untrimmed CAFD in E-Sys?
I can get the untrimmed data in the NCD/CAFD tool but i can't code in E-sys with trimmed value
Any trick i can use to get untrimmed?
Thank you
Old 08-18-2018, 01:43 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by babyk View Post
Hello
Thank you
All PSdzdata after 3.54 is trimmed.
NCD / CAFD Tool and Launcher Provide descriptions.
If you are not seeing data in E-sys, you selected wrong chassis in Premium Launcher settings.
Old 08-18-2018, 09:19 PM
Mein Auto: BMW F30
Dear Almaretto
I am using Launcher Pro V2.9, i can't select the chassis in the launcher.
I have a G30 and I selected S15A for the chassis and I can't see the trimmed value for the NBTEvo2
For the new F20, i also can't see the trimmed value in the new black Kombi
Old 08-18-2018, 09:47 PM
Almaretto's Avatar
Super Moderator
Dear Almaretto
For KOMBI, it may not be mapped.
For Evo, could be memory issue.
Old 08-18-2018, 10:04 PM
Mein Auto: BMW F30
do you think i can code FDL with the trimmed value?
there is a cheat sheet that can edit the value, can i code FDL with it?
Old 08-18-2018, 11:07 PM
Almaretto's Avatar
Super Moderator
E-sys only cares about werte values. If you know what to change, then you can Code FDL.
Not sure what you mean by Cheat Sheet that can edit the values.
Old 08-18-2018, 11:46 PM
Mein Auto: BMW F30
There are Cheat Codes which can apply on the trimmed value
Once I review and apply it, it will write to the FDL and i check with NCD/CAFD tool and it changed the value correctly.
i will go and make the coding then
Old 08-19-2018, 02:34 PM
Almaretto's Avatar
Super Moderator
If you can read in NCD/CAFD tool, but not E-sys, then there is configuration issue.
Old 08-19-2018, 09:36 PM
Mein Auto: BMW F30
yeah, do you know what is the configuration issue?
Where can i change the configuration?
I don't see much settings i can make in the Launcher Pro V2.9
Old 08-19-2018, 10:51 PM
Almaretto's Avatar
Super Moderator
Could be anything. I would have to connect to system to fix.
Old 08-21-2018, 09:45 AM
Mein Auto: BMW F30
I found the problem
it is the issue with the PSdZData
After revert back to the version earlier, now i can read all the trimmed data
Old 01-22-2020, 01:57 PM
ankneo ankneo is offline
Mein Auto:
I found the problem
which version worked?
