Build Log: M57 X5 - Page 2 - Bimmerfest - BMW Forums
Old 09-16-2019, 10:40 AM
2010xdrive35d's Avatar
2010xdrive35d 2010xdrive35d is offline
Mein Auto: 2010 X5 xdrive35d White
Another set of productive items I see! The first one that interests me is the fuel filter as I'm unaware of the last time it was replaced and didn't realize it had a date on the pump either. While that's probably a manufactures date still gives you an idea of when it was installed.
Really like seeing all the progress. Keep it up!
Old 09-23-2019, 06:40 PM
ucsbwsr's Avatar
ucsbwsr ucsbwsr is offline
Mein Auto: E61
Replacing vacuum lines turned into bypassing the low pressure EGR cooler and deleting the high pressure EGR cooler.
OEM vac lines had ~80,000 miles on them and were nice and toasty. Even with expanding pliers I wasn't able to get the lines off the nipples without cutting them with a razor. The last vac line I replaced was for the low pressure EGR cooler (located under the LP turbo) and accidentally broke the plastic nipple off. After doing some research I sounded like this wasn't worth repairing since I plan to delete it eventually and the non functional valve should only throw a CEL, not put the X5 into limp.
After learning my EGR delete intake pipe could be installed without limp mode I decided now was a good tie to do that as well. Even while on a stock tune I like having this done to slow carbon build up and have a nice bump in engine efficiency.
The e61 that's for sale gets the garage so the workshop moved to the driveway.
Roasted and toasted!
The best tip I have is to figure out how to remove this rear solenoid, reaching many of the vac lines is awkward but these two are impossible unless you pop the solenoid out.
I didn't see any holes but the lines were not in good shape
Farewell cooler
With the braces out I hit them with some sandpaper and applied some top coat, hopefully they stay looking fresh, I am a bit fan of brushed metals, especially in engine bays.
N54 Powered M5 Wagon:
- M5 Driveshaft, M5 LSD, M5 Axles, M5 Brakes
- M5 Front End, M5 skirts, M5 Mirrors, M-Tech Rep Rear
- KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC
- Manual Swap, MFactory SMFW, Spec Stg 3+ Clutch, Shiftteck SSK
- EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Ethanol Sensor
- N54B30, JB4, Hexon RR550s, Custom Y-Pipe Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC
E39 540iT:
- OEM Style 167, KW V1
- E38 Contour Seats
Old 09-23-2019, 07:24 PM
Evan, you never disappoint!
You've given me the confidence to delete the EGR as my next project. First I'm going to service the tranny and see how it does.
Old 09-24-2019, 06:23 PM
cluesblues cluesblues is offline
Mein Auto: 09 X5 35d|05 Subie Legacy
Subbed, I want to try and tackle some of this myself before winter hits. Great thread!
Old 09-24-2019, 08:29 PM
Scratch that... I'm going after this first. I was under the hood tonight and my lines look like yours. Instead of replacing them, why not just delete.
Two questions...
1. Where did you get your delete kit?
2. Did your CEL come on?
Old 09-24-2019, 09:13 PM
ucsbwsr's Avatar
Mein Auto: E61
Two questions...
It's important to distinguish the difference between the vac lines and "deleting" as they are not the same thing. You can delete emissions related stuff from the vehicle but you still need to replace the vac lines if they are in need.
1. My EGR valve delete pipe is from Bimmertune
2. Yes, there are some codes and the CEL light but no limp mode and the X5 performs as it should. I had my OEM EGR valve plugged in and tucked to the side in the engine bay. This is a temp solution until I am fully deleted. IMO better engine health > CEL light.
E39 540iT:
- E38 Contour Seats
Old 09-27-2019, 03:51 AM
Rumavil Rumavil is offline
Mein Auto: F07 + E70 + E36/7
Hi. Great stuff you´re doing here!
This is nothing, but I noticed you have your rear seat seat belts attached to their latch, whereas you can simply roll them and fix them to the D pillar - They have a place to fit them, instead of having them showing and eventually getting in the way.
Can send you a picture of mine if helps.
Small stuff ;-)
Cheers
Rui
Old 09-27-2019, 05:06 PM
ucsbwsr's Avatar
Mein Auto: E61
Small stuff ;-)
Cheers
Rui
Thanks for the suggestion, I would love to as I am not a fan of the 3rd row, I bought the X5 with t for the rear air suspension. In the US the rear seat belts do not disconnect like in other global markets.
https://www.realoem.com/bmw/enUS/sho...diagId=72_0583
E39 540iT:
- E38 Contour Seats
Old 09-28-2019, 11:34 AM
Flying Ace Flying Ace is offline
Mein Auto: M6 GC ZCP; '12 X5 Diesel
Wow! Great job and great pics!
1. That's a VERY clean OEM hitch install. Still baffles me the full OEM recommendation is to trim the entire center section of the bumper. Can you take a photo of the plugs, how are you able to get the plugs to work with it covered by your bumper? The OEM trim has the plugs exposed.
2. I agree Propel HPR is a great fuel and is good for diesel emissions equipment health. My closest station is 40 minutes away.
2014 F06 M6 (oil rig fire)
2012 E70 X5 diesel (oil burner)
2008 E90 M3 (oil distillates guzzler- Retired)
2013 bicycle (oily chain)
Old 10-03-2019, 12:07 PM
NW-99SS NW-99SS is offline
Mein Auto: 2009 335xi / 2012 X5 35d
Subscribed as well - great thread, awesome pictures, and nice work on your M57!
2009 335xi M6 Sedan
2012 X5 35d
Old 10-03-2019, 12:32 PM
ucsbwsr's Avatar
Mein Auto: E61
I would take another look at the pics I posted previously, I show how I trimmed the diffuser, how the plug is visible, and even a pic with the 4-pin connector installed. I don't know what else I could show.
Thank you!
E39 540iT:
- E38 Contour Seats
Old 10-03-2019, 01:26 PM
ucsbwsr's Avatar
Mein Auto: E61
First things first, welcome the new garage mate: Oliver! Soon to be 3 month old Blue Merle Australian Shepard.
Back to the basics: fresh oil
Next project was to run the wiring for my paddles, the electrical pins are in the mail so I figured it would be good to get the wiring done. I started by removing the wheel so confirm the M-sport paddles are configured like other M-sport paddles with resistors ...and they are. M-sport owners on other chassis remove the resistors to create a simple switch, others add additional resistors but in the spirit of KISS, I will explore a coding option I read about which will allow communication, if now then I have the other more permanent options to explore.
After some poking around I decided to run the wiring in this manner from the SZL; through the fire wall just above the dead pedal, from just under the brake booster out another grommet to the driver wheel well, up and over the transmission, and back to the electrical connector. There might have been a more direct way but this was fairly easy to access and the wiring is away from all the hot items on the passenger side.
Grommet above the dead pedal
View of the grommet below the brake booster
Thread the needle
In this pic you can see the wire ran behond the wheel liner. Wiring is tucked away as I wait for the pins to arrive.
Next project was aligning the rear tailgate which was pulled over to the passenger side. Using NewTIS I found the instructions for aligning the gate and played around with the loosing the bolts which connect the hinge to the body and the gate, it was a pain and didn't really work. To access these bolts you had to remove the spoiler.
Here is before
It isn't perfect but the most beneficial adjustment came from correcting the latch catch. If you lowered the tailgate down manually to where it was almost shut you could see it was pretty straight but then got all crooked when latched, DOH! I should have paid closer attention, removing the spoiler and playing with the main hinge wasn't necessary SMH. I also noticed the passenger side "bottom-out pad"? was about 5 millimeters higher so I brought that down to level. Maybe it was raised earlier to eliminate tailgate rattle? We shall see.
Here is after, not perfect but much better
Added some fresh felt tape to the latch catch.
Last project was fabbing up a PCV delete plate which will eventually house a bulkhead fitting and allow me to run an oil catch can. Just as others have done I used 1/3" aluminum hacked it up with an angle grinder and a Dremel. Considering my lack of metal fabrication experience and relatively primitive tools I am happy with the outcome. I bought a small vented Mishimoto "style" OCC but I know the Provent is the go-to for the M57 with a few internal mods. TBH the Provent is huge and looks like hell so I will see if I can get satisfactory results for another style OCC, if not then I will revert to the Provent and it's unsightly "do they really need to be this large of a diameter" hoses.
Good enough!
Keep it clean!
E39 540iT:
- E38 Contour Seats
Old 10-03-2019, 01:47 PM
Congrats on the new pup - beautiful!
Again nice work - all these pictures and descriptions are going to really come in handy for me. appreciate the time taken to post!
2009 335xi M6 Sedan
2012 X5 35d
Old 10-04-2019, 02:09 AM
So I have the pics, but can´t seem to understand how to post them. This is EU Model, so maybe the reason... Still you can probably get the parts and retrofit, I assume.
Cheers,
Rui
Old 10-04-2019, 09:24 AM
sunny_j's Avatar
sunny_j sunny_j is online now
bmw addiction
Mein Auto: X5d
Cheers,
Rui
I'd like to see a pic. Try using Imgur or something similar to upload to
2012 X5d | White on Black | Sports Package | EGR/DPF/SCR Delete | BRR Tune | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Log
https://www.bimmerfest.com/forums/sh....php?t=1290337
Old 10-04-2019, 10:53 AM
ucsbwsr's Avatar
Mein Auto: E61
There is a pic in this link, between this and the RealOEM link I posted above it should cover everything related to 3rd row belt storage.
https://xoutpost.com/bmw-sav-forums/...-how-stow.html
E39 540iT:
- E38 Contour Seats
Old 10-04-2019, 11:40 AM
sunny_j's Avatar
bmw addiction
Mein Auto: X5d
Thanks Even.
I'm working on removing the 3rd row from my x5. bought the replacement parts from the wreck for $100
Build Log
Old 10-10-2019, 05:10 AM
The pics I mentioned:
https://i.imgur.com/Gt49ccM.jpg
https://i.imgur.com/8EUmqKk.jpg
https://i.imgur.com/l76f64x.jpg
https://i.imgur.com/IbHTnLi.jpg
But probably you will simply remove the rear belts from D Pillar?
Cheers
Rui
Old 10-10-2019, 09:23 AM
Love the updates and LOVE the blue merle. Hey Oliver! We also have one. Female named Zoey. She's 2 years old. First dog and couldn't be happier about owning an Aussie.
Old 10-11-2019, 06:08 PM
ucsbwsr's Avatar
Mein Auto: E61
I finished wiring the paddles and got everything operational. I will be creating a guide explaining the process for E70s, there was info online but it wasn't definitive so I am hoping the consolidation of the necessary steps plus some pointers will be helpful for others. Keep an eye out for a link soon.
In addition to the paddle shift project the maintenance train continued to charge forward with the following:
- Fluidampr harmonic balancer + upgraded alternator pulley
- Water Pump + Thermostat
- New Belts
Removing AC stretch belt
Alternator pulley: Left-Old Right-New
Left: OEM balancer
Right: Fluidampr
OEM HB looked to be in good shape. There was no record of it being replaced in 85k so it's nice to know the Fluidampr is in there now, especially before tuning.
Noted some minor wheeping around the crank hub, not an urgent matter but it will be corrected at some point.
Old vs New
Cleaned, inspected, and greased up.
Refilled cooling system and got up to operating temp.
E39 540iT:
- E38 Contour Seats
Old 10-16-2019, 12:06 AM
scrllock scrllock is offline
Mein Auto:
Great thread, lots of interesting stuff. Don't own an E70 (yet?) but I do own a couple aussies. I have a nice setup in my E90, but I think a kennel in the back of an SUV is/was a much safer way of moving them around. Any idea on how big of a crate you can fit in the back? I was using a 31x22x24 and I'm curious what the clearance is like back there.
Thanks, enjoy the new puppy!
Old 10-16-2019, 07:19 AM
Still enjoying this thread as I plan future maintenance on our E70.
Got a few items looked after this last weekend:
Installed factory splash guards.
Swapped to winter wheel & tire setup.
Installed black kidney grills.
Replaced Lift Gate button in the center console - previous owner must have used her nails & scratched all the paint off.
Installed the BMW puddle lights under all the doors - some people think they are tacky, I like them.
Completed an oil change, topped off the DEF.
Installed an oil pan heater - so my wife can plug it in at work on the cold days (we get -40).
Cleaned the undertrays and coated the front subframe with spray wax in prep for winter.
New cabin air filters, new engine air filter.
Going to start ordering parts the OP has shown in this thread. Can you elaborate on the crank pulley? Is that a known failure item? Ours is at 74,xxx miles - so want to try and stay ahead of the maintenance.
2009 335xi M6 Sedan
2012 X5 35d
Old 10-16-2019, 09:14 AM
ucsbwsr's Avatar
Mein Auto: E61
I did a quick measurement and mycargo area is roughly 42" wide 28"-32" deep (depending on rear seat recline angle), and the height gets tricky since there is a lot to the ceiling but the angle of the rear glass cuts into that depending on the height of your item. From the floor to the glass is about 20" tall. I don't think you would have any problem fitting your crate in the rear, worst case scenario you might need to make the rear seat more upright but you may not need to.
In general the OEM harmoic balancer has a design the becomes compromised over time. It is metal in the middle where it bolts to the crank, the outside is metal where the belt resides, however those two metal pieces are joined by a rubber donut which becomes brittle, cracks, and eventually fails allowing the serpentine belt and crank hub move independently. The Fluidampr resolves this threat.
E39 540iT:
- E38 Contour Seats
Old 10-16-2019, 10:23 AM
ucsbwsr's Avatar
Mein Auto: E61
Paddles in action!
Also, this chirping noise shown below would happen periodically on start up, usually when the engine hasen't been ran for >12 hours. This was resolved when replacing my harmonic balancer, alternator pulley, and water pump. My guess it was caused by the alternator pulley.
I had some odd locking behavior, the driver door stopped unlocking at all and you needed to utilize the "actual" key however the driver door would lock with the FOB. Gas cap also needed a manual release to open. All other doors were unresponsive. Research said it was either a fuse or lock actuator. Thankfully it was a fuse, I replaced the 15A with 20A.
My initial fog light retrofit utilized 3M VHB which is amazing stuff but it didn't offer the structural rigidity needed for this application and with the heat sinks of the projectors completely exposed there was too much space for water and dirt to ingress so I revised the design.
To mount the LED projector bracket to the fog housing I used my ultra tiny drill bit and some steel wire to create 4 anchor points
Next was JB Weld which completely seals the perimeter and also adds rigidity.
Last were rubber housing caps to seal the rear, these work but they are a little excessive in their volume and the flange that grabs onto the housings could be deeper so I will be trying a different design later to optimize the design.
I gave the X5 a wash immediately after installing the revised fogs and so far so good, next wash will be with a power washer
I finally had the opportunity to take some output pics. Some things to note on these photos: The X5 is parked at a slight angle relative to the wall and the ground also has a slight angle which makes the output scale up in size towards the left. I did a quick aim of the projectors inside the fog housings before installing them into the bumper but never did another aiming once in the bumper, as you can see the driver side is aimed a bit higher and should be lower to match the passenger side.
The passenger side is aimed about as low as it can go, the projector assmebly bottoms out on the fog housing limiting the downward angle. I might be able to improve this a little by mounting the LED projector up a little higher in the fog housing when I join the two assemblies but the improvement will be small. The limited downward aim combined with the relatively high location of the fog lights in the X5's bumper these fog lights are more like supplemental driving lights. That being said with the ho-hum performance of the E70's adaptive xenon lights and the impressive output of the small LED fogs, they do a nice job complimenting the headlight's low beam output and help fill out the beam pattern. Photos are with an iphone and exposure is on auto.
LED fogs only
Low beams only
Low + Fog
Fog only
Here is a video cycling through the lights
E39 540iT:
- E38 Contour Seats
Old 10-16-2019, 11:32 PM
robinasu robinasu is offline
Mein Auto: M5
Thanks for all the pro tips!
Quick thought as I saw the CBU cleaning.. maybe flooding the cylinders with diesel and letting it soak might be a good way to loosen up the CBU on intake valves and runners. It's only about 3 to 4L, max. Of course, you'd want to extract the diesel before you start the engine. I have also seen that liquid moly diesel intake cleaner and other products like it.
How long did the purple soak take?
How did the engine feel with the swirl flap delete right after?
Similar Threads
First Drive: The BMW X5 xDrive30d and X5 xDrive50i pix335i X5 F15 (2014 - 2017) 7 10-09-2013 08:56 PM
2014 BMW F15 X5 productions starts at Spartanburg Plant tim330i X5 F15 (2014 - 2017) 1 08-10-2013 12:01 AM
BMW LA Auction Prices December 2008 searich07 General BMW Questions 0 05-14-2009 08:06 AM
X5 India Review TropicsX5 X5 E53 (1999 - 2006) 1 01-22-2007 05:16 PM
