AC Control does not work for the passenger side. - Bimmerfest - BMW Forums
Old 01-19-2020, 01:12 PM
ifoney ifoney is offline
Mein Auto: 335i
I have a problem with my F300 335i. The passenger side of the car seem to not want to follow the temperature set by the control. When I set it to max heat, it does blows luke warm while the driver side blow hot air.
What could be causing this?
Old 01-19-2020, 02:23 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 01-21-2020, 08:52 AM
DadzBmerN20 DadzBmerN20 is offline
Mein Auto: 2013 320xi
Just a stupid comment from me, but i assume you also checked the red/blue dial in the center of the two top vents correct?
2013 320i x-drive sedan
Bootmod3 Stage 1
20% 3M tinting front & back
Res + Muffler Delete w/Magnaflow Tip
Old 01-22-2020, 02:34 PM
Mein Auto: 335i
Yes, the red/blue dial is not the problem. AC blows cold when on max temp and dial turned to red all the way.
Old 01-22-2020, 08:00 PM
Ahh okay, at least that one is ruled out. I once had a 06' Honda Pilot that kinda of had your situation, it ended up being this part called: blend door actuator, it controls the air temps and it would get stuck and make a clicking type sounds under the dash area...
Bootmod3 Stage 1
