need some help w/ diagnostic codes - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-18-2005, 06:56 PM
drpahjee drpahjee is offline
On my 4th Bimmer...
Mein Auto: '10 X5 M
Question need some help w/ diagnostic codes
i have these codes:
018 camshaft: exhaust
227 O2 bank 1 & 2
228 Control deviation
would appreciate any help re: parts #'s needed to be replaced
thanks.
Old 01-19-2005, 03:28 PM
On my 4th Bimmer...
Mein Auto: '10 X5 M
anyone?
Old 01-19-2005, 04:48 PM
CSquared CSquared is offline
Mein Auto: 2002 325i
From my Bentley's
018 (P Code P1397) Exhaust Cam position sensor malfunction INTERNAL CHECK OF PHASE SHIFT FROM CAMSHAFT SENSOR - SHOULD CHANGE DURING EVERY CRANKSHAFT REVOLUTION. PHASE SHIFT OCCURS DUE TO 2:1 RELATIONSHIP BETWEEN CAMSHAFTS
227 (P0188) Fuel Trim (Bank 1) O2 control adaptation limit RANGE CONTROL OF ADAPTATION VALUES
228 (P0189) Fuel Trim (Bank 2) O2 control adaptation limit RANGE CONTROL OF ADAPTATION VALUES
Old 01-19-2005, 05:00 PM
Kaz's Avatar
Kaz Kaz is offline
King of Rear Clunks
Mein Auto: 01 325iT, 88 M6
Dead exhaust cam position sensor is common. Is the car out of warranty or something?
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline
1988 M6 Royalblau/Silbergrau Nappa
Old 01-19-2005, 08:58 PM
On my 4th Bimmer...
Mein Auto: '10 X5 M
yup, just about to hit 60K;
so should i just initially replace just the position sensor? i'm not sure what i can do about the last 2 error codes
(thanks, csquared)
Old 01-20-2005, 09:04 AM
Pvt. Joker Pvt. Joker is offline
Mein Auto:
The mileage length of a warranty is not always firm. I had a valve tappet replaced under warrranty when I was 2,000 miles over the mileage on an Eclipse. Try talking to your service manager.
Similar Threads
PEAKE R5/fcx code/reset tool and understand the codes reevesna Do-It-Yourself H.Q. 2 12-29-2006 11:57 AM
could someone help w/ diagnostic codes? drpahjee 3 Series & 4 Series 0 01-13-2005 08:54 PM
Location of option codes Silver328i 3 Series & 4 Series 3 08-22-2004 02:36 AM
Fault Code Readings - diagnostic help please! KenC-VA 5 Series 2 06-29-2004 10:45 AM
Status codes still used? damills Ask-A-BMW-Dealer 9 09-07-2003 08:05 AM
