BMW 318i battery failure - Bimmerfest - BMW Forums
Old 11-11-2019, 03:29 AM
coathangers coathangers is offline
Mein Auto:
My BMW 318i 2007 95kw has recently broken down because (I hope) the battery is faulty.
Do BMWs behave strangely when running on a low power battery?
Mine is giving me all the warning lights under the sun and abs and transmission won't work properly even if the battery is hooked up to a charge pack. Is that normal? How can the electrics interfere with the mechanics so much? It seems as if the battery is integral to everything including fuel injection and transmission, but that seems dangerous.
Old 11-12-2019, 02:45 AM
Mein Auto:
I am not asking for help with repairs here! I am getting it sorted hopefully.
Just really after some general advice from BMW owners with experience. When the battery is running low, what kind of issues does it cause? Mine has gone haywire with the ABS and transmisison and fuel injection all buggered!
Old 11-12-2019, 05:40 AM
relative4 relative4 is offline
Mein Auto: '08 335xi E90 manual
Yes.
Old 11-12-2019, 07:21 AM
marvinstockman marvinstockman is offline
Mein Auto: 1997 M#
Why don't you buy a cheap multimeter, and measure battery voltage with car off and car running? Youtube for DIY.
Old 11-12-2019, 08:51 AM
Jim328 Jim328 is offline
Mein Auto: 2008 328xi
With low voltage, the BMW will go absolutely bonkers.
There's eleventy-thousand computers, all of which require an appropriate power supply.
If your battery is old, it won't hold a charge, the voltage is low, blah blah blah.
Buy a multimeter to check voltage.
Better yet, ask a friend who has a multimeter to check it.
A 2007 vehicle should already be on its second battery by now.
I have Jeeps that consume a battery every 4 years or so.
After you replace (or have someone replace) the battery, you need to tell the car you've installed a new battery. When the vehicle is aware of a new battery, it will alter the charging pattern to get maximum life from the battery.
I'd go with a new battery, but that's just me.
Your mileage may vary.
2008 328xi
BMW CCA
Old 11-12-2019, 12:19 PM
Mein Auto:
Really appreciate the response. Definitely getting a new battery ASAP plus the on board computer to usb cables to register it.
I think my main worry is with all the computers, does the car do anything on it's own mechanically? Will the radiator cooling fan work? Will the oil be regulated? Seems crazy. I know the thing is currently unusable now and won't even start, but with the battery being low for a while I wonder how many of those little processes have been failing.
Will look to get the multimeter too to avoid this happening again.
Old 11-13-2019, 07:05 AM
Right now, it's just like being parked for an extended period.
With a new battery, everything will come back up just like it should.
Happily for us, Microsoft did not write the software in our cars.
2008 328xi
BMW CCA
