2006 e60 525i Auxiliary Water Pump - Bimmerfest - BMW Forums
Old 05-13-2019, 12:28 AM
pKaTz pKaTz is offline
Mein Auto:
Hi. Sorry if this has been asked before.
I have a 2006 525i with 51500 miles on the clock. The other day driving home the fan was constantly on and the amber engine over heat warning came up, and then the red warning.
Later in evening when cooked down I checked coolant level and it was at minimum so topped up, but just after starting car fan comes on again. So I take the car to be plugged in and check error codes. The auxiliary water pump comes up as having spped deviation and also switching off.
Car is now at a garage and will be seen today.
Should I ask them to just check and change the pump?
Would you suggest changing thermostat too or anything else while there (timing belt?)
I'm in Birmingham, do you suggest I source the part myself? Also where can I get it.
Thanks in advance.
Thanks for any suggestions
Old 05-13-2019, 05:47 AM
marcozandrini marcozandrini is offline
Mein Auto: 2018 M240i
The first step in diagnosing a problem is to scan the engine computer (DME) and the automatic transmission computer (EGS) for codes. Thats the only way to troubleshoot a problem in a modern car. You say youre in Birmingham. Is that Alabama or England. If its Alabama go to www.bimrs.org to find a reputable indie shop that specializes in bimmers.
Old 05-13-2019, 06:40 AM
Mein Auto:
Originally Posted by marcozandrini View Post
The first step in diagnosing a problem is to scan the engine computer (DME) and the automatic transmission computer (EGS) for codes. That's the only way to troubleshoot a problem in a modern car. You say you're in Birmingham. Is that Alabama or England. If it's Alabama go to www.bimrs.org to find a reputable indie shop that specializes in
bimmers.
Thanks for the reply.
I am in the UK so England.
On checking faults the codes that came up were 2E81 and 2E82
Old 05-13-2019, 07:10 AM
Underwurlde Underwurlde is offline
Mein Auto: BMW E63 630i
Check realoem.com for part numbers, but should be same as mine.
Got mine here, original parts, great price:
https://www.ebay.co.uk/itm/153449815195
Once you start getting pump errors its time to change....
Old 05-13-2019, 11:07 AM
Mein Auto:
time to change....
Wow almost 300 for an auxiliary pump.
Old 05-14-2019, 01:53 AM
Mein Auto:
The car is at the garage today and will see how much this is going to cost. The part is costly so I'm sure will be about 500.
Old 05-14-2019, 10:36 AM
That's for pump, thermostat and replacement bolts. You can get pumps on the cheap but when it comes to the cooling system it's just not worth skimping.
Old 05-14-2019, 01:09 PM
Mein Auto:
I got the oil and filter done too. Cost 500 all in.
Old 05-14-2019, 03:55 PM
That's a great price, you did well. Any idea what parts were used?
Old 05-15-2019, 01:08 AM
Mein Auto:
No. I didn't ask. Just glad it's all done now. ***x1f605;
Old 05-18-2019, 12:11 AM
Mein Auto:
I didn't get the thermostat changed when got the pump changed, and notice that after driving about 9 miles with outside temp about 9c the coolant temperature went up to 109c and no fan on. Is this normal?
Or should I go back and get a new thermostat?
Old 05-18-2019, 04:24 AM
Mein Auto:
Actually after driving it does go down. So is ok. Fingers crossed.
Old 05-18-2019, 06:01 AM
109*C is way too high, especially since the efan didnt come on. Did the efan come on before the work? What brand is the new water pump?
Old 05-18-2019, 10:18 AM
Mein Auto:
109*C is way too high, especially since the efan didn't come on. Did the efan come on before the work? What brand is the new water pump?
I'll have to ask the garage which one they fitted. As didn't think to check
Old 08-22-2019, 02:33 PM
domenickjuliano domenickjuliano is offline
Mein Auto:
P2eff
My Fan isn't coming on either...
the car overheated while parked and idleing... I replaced the reservoir and automatically bled the system for 10 or 12 minutes and the water pump worked just fine bleeding the system...
I have not really driven it but the car at idle with a/c running coolant temperature increased to 103 without the fan ever turning on... I turned off the car at that point.
The code that came up from ELM 327 with Car Scanner app says P2EFF
https://drive.google.com/file/d/1VKw...ew?usp=sharing
any ideas?
Similar Threads
2004 X3 Starting issue. mrsimian X3 E83 (2004 - 2010) 42 09-09-2016 10:13 AM
AAA is towing my car in 30 minutes (total electrical failure) bluebee E39 (1997 - 2003) 220 07-06-2015 01:15 PM
Need help to diagnose a faulty water pump 2006 E60 greengeco E60 / E61 (2004 - 2010) 34 03-06-2015 12:42 PM
operation of auxiliary water pump 2004 E60 M54 Zyb E60 / E61 (2004 - 2010) 22 10-31-2013 06:29 AM
DIY: A/C Belt Tensioner Replacement EconoBox E39 (1997 - 2003) 8 02-11-2013 06:56 PM
