2013 f25 35i m-sport - dynamic damper reset? - Bimmerfest - BMW Forums
Old 05-08-2019, 01:12 PM
lbjgh's Avatar
lbjgh lbjgh is offline
Mein Auto: 2013 X3 M-Sport
Our '13 X3 has dynamic dampers and the car seems to have developed pretty poor ride characteristics.
I hadn't driven the car in a while as it's my wife's daily driver. The car has developed a weird "washing machine" feeling ... very weird.
I put the suspension in sport mode and the car felt better but I want to return to comfort mode without the sloshing feeling. I'm sure the stealership will want $5K to replace all of the suspension. :o
Is there a factory reset option hidden somewhere to reset the suspension/dampers?
Thanks LBJGH
Old 05-08-2019, 04:46 PM
DBU's Avatar
DBU DBU is offline
Mein Auto: Glacier Silver X4 M40i
Thanks LBJGH
Almost certain there is no "reset" anywhere. Have you checked the tires? If they are getting worn they can/will change the personality of the car IMHO.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 05-09-2019, 11:09 AM
heyheyitsmarc heyheyitsmarc is offline
Mein Auto: 2016 X3 35i xDrive MSport
I've noticed in my BMWs more than any other cars I've had that when the tires wear too much, the vehicle starts tramlining. The first time I experienced it, I thought there was something seriously wrong with my car. Problem went away when I switched my seasonal tires out. Both of my F25s (and my E92) have had this issue
Old 05-09-2019, 09:41 PM
lbjgh's Avatar
Tires are good as is pressure.
Old 05-18-2019, 05:48 PM
scostuart scostuart is offline
Mein Auto: 2014 F31
Thanks LBJGH
No Reset. How many miles on your X3?
Dynamic dampeners wear out faster than static suspension.
How many miles on current tires?
Are you on RunFlats?
Staggered or square wheel setup?
Old 05-19-2019, 07:00 AM
lbjgh's Avatar
140k Kms
Non-run flats
Square
Maybe Iíll increase tire psi a bit....
Old 05-19-2019, 09:22 AM
pungo's Avatar
pungo pungo is offline
Mein Auto: 2007 Z4MC , Corrado G60
140k Kms
Non-run flats
Square
If the psi is set to spec, I don't think increasing it would improve handling.
Have you bounced on the corner of the vehicle to test the struts/shocks to it it continues to move after releasing it?
Depending on the road conditions the vehicle has been used on, the struts may be worn out? Very $$$ to replace.
If you're coming from a car with a decent suspension, the X3's taller and longer travel suspension will have a more boaty feel.
Old 05-19-2019, 11:56 AM
Mein Auto: 2014 F31
140k Kms
Non-run flats
Square
Take it to a trusted INDY mechanic so they can test/ inspect your suspension.
Might need new bushings and dampeners since vehicle is over 6 yrs.
Similar Threads
2013 535i M Sport - Dynamic damper control boshaugh F10 / F11 (2011 - 2016) 2 03-09-2016 12:57 PM
A Look at the Audi Sport Quattro Concept. [email protected] General Automotive Forum 5 09-06-2013 05:23 PM
BMW Service Codes 00000000 through 09999999 mksu19 General BMW Questions 7 02-22-2013 07:07 PM
