Emissions P0441 vacuum leak - Bimmerfest - BMW Forums
Old 05-13-2019, 11:06 PM
u023 u023 is offline
Mein Auto: '01 BMW 330i
I'm trying to resolve a stubborn P0441 (Evaporative Emission System Incorrect Purge Flow) CEL in a 2001 E46 330i A/T with 140K miles for an upcoming emission test.
The car has a new purge valve and new gas cap. CEL will come on as part of drive cycle.
Following 3 circuits are not ready: Evaporative System, Secondary Air System, Oxygen Sensor Heater.
I've made a DIY smoke device and see minor amounts of smoke to the right (looking from the front of the car) of the intake. Can someone identify this part of me? Smoke is coming from the areas with the red arrows. Is it part of the cruise control? Any guidance for repair?
The P0441 is the only code thrown.
Oxygen sensors are likely original.
Thank you.
JD in Berkeley California.
Name:	2001 E46 330I AT smoke.jpg
Old 05-13-2019, 11:37 PM
Never mind. Found plenty of posts on the DISA valve.
Old 05-14-2019, 11:53 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
you've probably got the "o" ring by now and replaced it...wish that was my problem,,,well, maybe not!
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 05-14-2019, 01:54 PM
archbid archbid is offline
Mein Auto: 330ci Convertible
As an aside the o2 sensors have a 100k maintenance interval. Would encourage you to change. If you still have issues with readiness there is an ecm update that deals with it
Old 05-18-2019, 07:01 PM
@archbid - Thanks for your advice on the oxygen sensors. Two new front oxygen sensors and a new disa o-ring and the car passed emissions.
Old 05-18-2019, 08:43 PM
Awesome!
Similar Threads
Might we be able to list, with pics (realoem diagrams ok) of ALL E39 vacuum lines? bluebee E39 (1997 - 2003) 56 08-17-2019 05:43 AM
35d with turbo leak - exhaust smell in cabin - vacuum hose line damage - fix with pic stevieg58 X5 E70 (2007 - 2013) 22 04-22-2018 08:17 AM
DISA BMW Repair kits timons The Detail Department 0 09-17-2015 11:41 PM
DIY - Most Common Vacuum Leaks (Diagnosing P0171 & P0174) 50sKid E46 (1999 - 2006) 1 06-05-2015 12:00 PM
Gas Cap Won't Come Off/P0174 Engine Code jordandhale E46 (1999 - 2006) 27 07-02-2014 10:18 AM
