Is there a way to fix the "dampening" feature on the center console doors (ashtray)? - Bimmerfest - BMW Forums
Old 05-18-2019, 07:31 PM
Santaclaus4 Santaclaus4 is offline
Mein Auto: Two 2003 540i Msport's
I've been cleaning the interior of my project car (it's really gross) and I've noticed that the ashtray door opens so fast it pops the ashtray out. I've got the center console apart and separated the wood trim from the plastic. I washed all the parts in warm slightly soapy water to get all the PO's spilled pop out of the mechanism's as much as possible. I even washed the circuit board (with the LED) that lights up the ashtray and the cigarette lighter. There was so much sticky pop on everything that I could have re-constituted it into several "big gulps".
It looks like there is a small gear (with it's own tiny housing) that provides the damping feature. I'm gonna assume it's not something I can purchase from BMW as a separate part. I don't necessarily want to take that little housing apart since it's "staked" in place. The damping feature still works fine on the lighter but not on the ashtray.
I even took the center stack out to clean around everything. There was old, sticky pop all down the front of the console, including the MID buttons. I installed new cup holders while I had everything apart. They will never be used, ever! They are just there to fill the hole. Lol
ID:	852337   Click image for larger version
2003 540i M-sport
If you put cheap parts on your car, you'll soon have a cheap parts car.
The law doesn't determine right from wrong. They are unrelated.
Old 05-18-2019, 09:22 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Years ago, the dashpot on the CD player door broke off the little locating tabs, at the time a common failure. I was able to refasten it with some epoxy. It still works.
I don't see the dashpot in your pics, but you may be able to fasten it in a similar fashion.
My go-to is JB Weld.
Old 05-18-2019, 09:39 PM
It's not broken off, it just spins freely.
2003 540i M-sport
Old 05-19-2019, 01:01 AM
Look at what I found...
https://www.cultraro.it/en/two-ways-...tary-dampers//
2003 540i M-sport
Old 05-19-2019, 01:11 AM
All you ever wanted to know...
https://www.bibus.at/fileadmin/edito...ue_en_2009.pdf
2003 540i M-sport
Old 05-19-2019, 09:48 AM
mattmar1's Avatar
mattmar1 mattmar1 is online now
Wingnut
Mein Auto: 1999 5281 5 sp msport
unfortunately i had just tossed out a complete working assembly or you coulda had it.
99 528i 5sp sport
be alert...the world needs more lerts
Old 05-19-2019, 05:34 PM
I totally get that. You save parts in case "some day" they are needed. As soon as you toss them out, they are needed. Been there many times. Lol...
2003 540i M-sport
Old 05-19-2019, 07:59 PM
The center console is all back together. It looks pretty good and I think that no one but me can tell the wood laminate is still a little warped. The cracks I made clamping it flat while it cures are hard to see now that it's in a more relaxed state again. Heck, I even washed the buttons (central lock and flashers). They were so gummed up with sticky pop that I had no choice but to throw them in the sink for a few seconds. I blew them dry and reinstalled them and they work fine.
2003 540i M-sport
Old 05-19-2019, 10:06 PM
1BlinkGone 1BlinkGone is offline
Mein Auto: 2003 530iA, prod. 4/29/03
IF I may piggyback on the OP topic, we have a similar situ with the same ashtray. Looks like soda has been spilled in there from PO's, and the lid won't stay shut and the ashtray keeps popping up. Our "mech" said something is broken in there, but I'm not convinced. I did take a swab and remove much of the goop and tried to clean the little gear, etc. Still the lid won't stay shut & ashtray keeps popping up. So I have a little piece of plastic wedged in there to keep the lid shut. Any ideas? thx.
2003 530iA Sterling Grey/Montana Grey base; Sport seats; M-Sport SW; Xenons; 17" S42 BBS/BMW Wheels
Old 05-20-2019, 12:58 AM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
i was about to start yelling.. LIKe WHO THE HELL has garlic salt and pepper on there work bench..
Then i realized.. thats the kitchen counter lol
matt that center roll up door blew up again lol
Idk
Specializing In Breaking Things Professionally
15486372<-----
Old 05-20-2019, 06:03 AM
mattmar1's Avatar
Wingnut
Idk
from that one i sent you some time back? howd that happen?
99 528i 5sp sport
Old 05-20-2019, 08:38 AM
Joe-BMW's Avatar
Joe-BMW Joe-BMW is offline
Mein Auto: F10, E39, Audi Q7
I picked up an entire the mechanism/insert used on ebay. It's kind of one of those things you gotta keep searching for and eventually one will "pop up". My car was missing it completely when I got it. PO much have something installed in there, guessing a radar detector head unit.
2003 540i|Jet Black|Gray Interior|M-Sport|WS NAV|Shades|PDC
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|745li|2007 750li|2006 750li|2001 530i|2012 535xi|
Old 05-22-2019, 08:54 AM
Skarv Skarv is offline
Mein Auto: '05 645i convert
Not familiar with your exact damper, but most rely on heavy silicone grease for the damping effect. If you find the little cylinder with a gear on it, see if it has any holes at all. If it does, get a syringe and squirt some fresh plumbers grease in the hole. You need high temp grease so it won't drip out on a hot day. Good luck
Old 05-22-2019, 09:04 AM
Shoot, that's a friggin good idea.
2003 540i M-sport
Old 05-22-2019, 09:10 AM
Burning2nd's Avatar
Under the lift arms
I dont know man.. i just went to open it one day.. for what ever i was looking for (probably the keys for the roof rack)
and when i went to close it.. It just closed with out the door
just like the first one..
so i sat there and i was like... I did replace this? someone on the forums hooked me up...
that did really happen right? is this a glitch in the matrix?...
lol im literally looking in the rear view questioning reality at that moment
15486372<-----
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
center console keylock fix Darby123 7 Series - F01 / F02 / F03 / F04 (2008 - 2015) 0 01-30-2016 08:49 AM
The MINI Countryman - Fun has no Limits tim330i BMW News 0 01-21-2010 11:10 AM
For once and for all, I'm not a smoker... How to fix your ashtray door W.S. E39 (1997 - 2003) 7 04-20-2008 10:07 AM
Quality issues with the 1 series in Europe Fifty_Cent E82 / E87 / E88 / F20 1 Series (2008 - 2014) 21 03-18-2008 02:14 AM
