2009 128i Warning Lights - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
Old 03-10-2019, 08:55 AM
After guard After guard is offline
Mein Auto: BMW 128i convertible
I have a 2009 128i (E88) with 113,000 miles on it. Went out this morning to go to Home Depot and upon starting the car I was faced with the following warning lights: ABS, DSC, Brake, and Check Engine Soon, and TPMS.
The TPMS has been out for a while because the TP sensor batteries are dead on all four wheels. I ensure the tire pressure is in spec every weekend, so I've been ignoring the TPMS warning until I replace the tires, when I'll also replace the TP batteries.
The Owners Manual has a section in the warning indicators that includes this combination of warning lights, and the special actions to be taken are simply to drive carefully and have the problems sorted out as soon as possible. Interestingly, the reference to the "fix" for this goes back to the TPMS portion of the owners manual. So I'm kinda thinking that the old TPMS failure may be at the root of the problem.
Planning to take the car in tomorrow to have my very good dealer do a check on it. Curious if anyone on the forum has had this occur to them?
Old 03-14-2019, 11:32 AM
QuebecDIY QuebecDIY is offline
Mein Auto: 135i 2008
Not sure, but last time I had something similar to that (on another make of car) it was the alternator not charging and battery being very low... So everything was going nuts coding for because of too low voltage.
Check first if you still have an alternator belt on. (quick one).
Old 03-15-2019, 07:03 AM
Thanks for your reply! I had considered that it may be a low battery and did a battery check. It was a good 13.5-14 Vdc and the alternator was working okay. (I have done most of the routine maintenance on the car since since new.)
Truth is I had experienced something very similar to this a couple of years ago but not so many warning lights. So I took it to the dealer and it turned out to be one of the ABS wheel speed sensors. All four sensors had been replaced less than two years ago and were still under warranty so it was a no-cost fix. Woo hoo!
Old 03-26-2019, 09:46 AM
jaye944's Avatar
jaye944 jaye944 is offline
Mein Auto: 128i Cabriolet '12
when was the battery changed last
__________________________________________________ ____
IF you DON'T like my post "MOVE ON"
IF you DON'T like my reply "IGNORE IT"
If your rude you'll get "IGNORED"
Similar Threads
330i Brake, ABS, and DSC Warning Lights On tinkering E46 (1999 - 2006) 12 12-07-2018 03:53 PM
Weird and unreasonable warning lights after rain d_kenneth X5 E70 (2007 - 2013) 3 06-24-2018 08:29 AM
update on dash warning lights WILLIA///M 3 Series & 4 Series 18 12-22-2002 11:56 AM
Q. regarding warning lights gbrown E36/7 Z3 (1996-2002) 6 08-29-2002 12:35 PM
