Multiple electric circuit error - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 / F20 1 Series (2008 - 2014)
Old 04-27-2019, 02:01 AM
Iceman3_2010 Iceman3_2010 is offline
Mein Auto:
I have a f20 118i which experienced an oil leak from the oil filter cap gasket a few days back. Multiple error codes short to earth have been present since.
Error 1B5302 terminal 15N_2, voltage supply switched by FEM, electrical: short to ground
Error 130002 vanos solenoid valve, intake, activation: short circuit to earth
Error 130202 exhaust vanos solenoid valve, activation: short circuit to earth
Error 122002 blow off valve, activation: short circuit to earth
Error 1C0202 engine oil pressure control valve, activation: short circuit to ground
Error 102A01 hot film air mass meter, signal: electrical fault
Error 120408 charging pressure control, deactivation: pressure build up blocked
Car is running fine with a slight misfire. Any ideas what could be the cause?
Similar Threads
BMW Fault Codes OBD,DTC igor2009 BMW Coding and Programming 1 11-24-2019 05:28 PM
E60 start problem / rough idling stranger12 E60 / E61 (2004 - 2010) 4 03-21-2015 04:30 PM
Extracted these error from INPA, should I worry? vitchie BMW Coding and Programming 0 01-21-2014 12:23 PM
Reference - Common error code list wilson009 7 Series DIY 0 02-08-2010 11:56 AM
