Here are logic 7 repair instructions for every 1 - Page 4 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 04-12-2014, 03:37 PM
priitcce priitcce is offline
Mein Auto: car
Hi
The subs on my car went dead (rear doors and center still works). Took the amp apart and tested the caps. All seem ok. Replaced the sub amps with tda1562q chips. Still not working. No corrosion damage or damage to other components. Does anyone have any ideas?
Priit
Old 04-22-2014, 06:22 AM
tovi tovi is offline
Mein Auto:
I have 03 745i i replaced emergency brake module and after 5 minute of driving all the light comes on the dash anyone
  #78
Old 04-22-2014, 07:18 AM
vernon3rdw vernon3rdw is offline
Vito
Mein Auto: 7 series
Was it the ABS module You replaced
Sent from my SAMSUNG-SGH-I727 using BimmerApp mobile app
Old 04-22-2014, 07:22 AM
thunderkyss thunderkyss is offline
Mein Auto: 745Li; 2004
Whatever it was, probably had nothing to do with the Logic7
2004 745Li
  #80
Mein Auto:
Yes it was the abs module
  #81
Old 05-11-2014, 01:39 PM
nelutu nelutu is offline
Mein Auto: bmw
Originally Posted by PAPER View Post
I think you mean the WEST coast .
& as for the chips , they are available .
Just use Google search or buy them on Ebay
Sent from my GT-N7000 using Bimmer App
Hi I have my bmw 730d 06 plate how much cost the map navigation ? thanks nelutu
  #82
Old 06-27-2014, 01:01 AM
Romey-Rome's Avatar
Romey-Rome Romey-Rome is offline
Mein Auto: 750li
Am I reading that right? pin 4 & 16 go to the same pin? On the amp...
Edit: Found the answer. Clearer pics here. http://www.drive2.ru/b/288230376152265355/
  #83
Old 08-30-2014, 10:49 AM
james69z28 james69z28 is offline
Mein Auto: 2004 545i
great info, does anyone know who the guy is that does repair on the logic 7 amps reasonable, I have read on the net about him but can't locate his e-mail address?
send reply to [email protected], and THANKS for all the info we need more guys like this!
  #84
Old 09-05-2014, 06:07 PM
whytry's Avatar
whytry whytry is offline
Mein Auto: '07 750Li, 68 Camaro
I just did the repairs and used the kit from pixelfixltd and I got this screen below. Any ideas on how to get this thing back up n running?
06 750i - Blk/Blk, Sport pkg, premium pkg, comfort access, ent pkg, convience pkg, 21's, sold
07 750LI - Blk/Blk, Sport, Premium, comfort access, rear DVD, convenience, 21's, sold
08 750LI - Wht/2 tone, comfort access, Ent pkg, convience pkg, 22's, tint, recoded and just TOTALED
68 Camaro - Procharged and injected LS2 in progress
  #85
Old 10-21-2014, 04:13 PM
mrnyc mrnyc is offline
Mein Auto: 745li
Anyone know of ask and L7 repair shops in NY or east coast?
  #86
Old 01-28-2015, 01:50 PM
02beam 02beam is offline
Mein Auto:
HIS 3'RD POST
I have now a new pair of images from a user.
Have now labeled this.
So much fun with it : Thumbsup:
HP. Here you can see how difficult it is to enfernen the old amps without damaging the contacts
Hey paper do you still have any harness adapters for ant up integration
  #87
Old 02-17-2015, 09:07 AM
akarro akarro is offline
Mein Auto: BMW 735i 2002 E65
Hello
I have and logic 7 amp processeor board what does not start up. I have a working board also and verified, that amp and power board is okey. Have nice 5V and 3,3V and it works with the board. So I have a problems somewhere in firing up circuit. The bad board does nothing, just found a stand by 5V what seems to be ok. Measured and compared transistors to good board. No differences. With the good board amp show a red light for a little while and then shuts down, what is normal. Bad board does not fire up a optical red light also nothing.
The amp IC-s where also all burned when got the amp, replaced them and power-amp board works with my backup digital board. So the problem is 100% in the digital board, but nothing blown, or have not found yet.
  #88
Old 02-17-2015, 12:17 PM
the faulty board now powers up for a second or two and then switches off. In car it keeps restarting. 5V and 3,3V measured ok. The processor nr 1 is cold and does not warm up. Processor nr 2 is warm....normal working condition I think.
  #89
Old 04-21-2015, 04:50 AM
rrdsgn rrdsgn is offline
Mein Auto: BMW
L7 Problem
Wow, amazing work stuartjohn24!
Unfortunately i have another model of the Logic7 Amp but i have the same issue that the amp keeps waking the whole car probably because of a broken transistor.
i took a look at the circuit board and found one that does not look very good.
Do you know if it is possible that this one in the left corner is broken?
Regards
R
  #90
Old 04-21-2015, 11:37 AM
BeachTroy BeachTroy is offline
Mein Auto: 98 RSTC
Quick question for you Paper, what did you use for the center channel? It's the only one I don't see a picture of with pin numbers.
Excellent Post and Great job. Thank You Very Much
  #91
Old 06-21-2015, 02:50 AM
tipsydc83 tipsydc83 is offline
Mein Auto: 745i
Originally Posted by stuartjohn24 View Post
Nice information!
My AMP finally blew tonight.... Well at least I think it has, my idrive has been playing up intermittently every now and then for a month or so.
Tonight I got in the car and there is music playing but only for a second, then stops for a second then plays for a second etc... at very low volume and crackly. music only come out the front door speakers.
The idrive keeps reverting back to the radio menu, the TV functions dont work it wont select a channel, I can select ipod tracks with a few attempts but they wont play unless you keep trying! and the ASK wont play CD's! Also the MMI wont shut off after I have removed they key!
INPA cannot communicate with the AMP so im assuming thats the issue? It sounds more serious than just the capacitors or amplifier IC's going down and more like the actual MOST interface itself is rebooting. Or could the AMP be rebooting as one of the caps are short and its PSU is overloading and trying to restart?
Will pull it out and loop the MOST bus and see if it is indeed the problem!
Stuart
My amp is doing the same thing!! Where are you located Stuart? How much would you charge to fix mine?
  #92
Old 06-24-2015, 04:45 PM
stftmin stftmin is offline
Mein Auto: E-30's
ASK unit
Cool stuff guys. I got the new amp circuit board, for my ask unit, from diyparadise but not the instruction video link to show what color wire goes where. Been practicing on an old amp board to make sure I am comfortable and feel I can handle it.There are thirteen total wires plus a larger black wire, am assuming a different power source location. Anybody have the instruction sheet? Saw the picture of the unsoldered chip with 13 pads. Do i need two of these, one for each amp? Thanks and awesome info!
Jay
ID:	516026   Click image for larger version
  #93
Old 07-03-2015, 07:37 PM
someguy813 someguy813 is offline
Mein Auto: 750LI
Jay
I also ordered and received one of these ASK boards and have no wire schematic. Does anyone have this?
  #94
Old 07-08-2015, 03:35 AM
wdriver wdriver is offline
Mein Auto: 2002 E65 745i
Hi,
I have a 745i, 2002. The amp maybe Logic 7 is overheating in summertime,
after a 5 minutes comes back. This time totally stopped the sound system.
i read Your DIY, but Im not sure, i have to change the chips, or the capacitors?
I just didn't find, wich repair work is need if I have this problem.
and now, i dont have radio, slowly goes out, sometimes worked, sometimes not, but 1 month ago nothing from the radio. CD is ok, if the Logic 7 works
thanks from Hungary
  #95
Old 07-19-2015, 07:13 PM
rippjd rippjd is offline
Mein Auto: 07 530xiT
Jay
I take it there is no instruction video link anywhere in the package?
I had someone in the UK repair my ASK unit many years ago. However only the left side speakers were not functioning, so I required only wiring to replace that one IC. Below are 3 photos.
The new amp IC didn't function when I first received it (seller acknowledged they weren't familiar with the ASK unit, more so with the similar BM54 for i-bus BMWs). Then I moved the blue StandBy wire to the location in the photo and it's been functional ever since. The module he used had 2 blue wires, the one closest to the new amp ICs was used for the Standby Signal. The 2nd blue wire was not used.
I moved the black wire (+ Power) to the location shown for a cleaner install. Good Luck!
EDIT: I found the company in the UK who did the repair: http://www.carphonics.co.uk/
EDIT 2: I used one of these kits to fix another ASK unit and posted pictures in Post #93 here: https://www.bimmerfest.com/forums/sho...=565121&page=4
Name:	Audio Input z.jpg
ID:	520693   Click image for larger version
Name:	Positive Power Tap.jpg
ID:	520694   Click image for larger version
Name:	StandBy Signal 3z.jpg
2007 530xiT
2010 X5 35d, 2005 745i, 2000 740i, 1999 540i, 1994 525i - all SOLD but not forgotten
E65/E66 Parts for Sale: Alpina Type 743 Front Spoiler kit (new in box) $1200
  #96
Old 09-12-2015, 02:51 AM
Musicianpwr Musicianpwr is offline
Mein Auto: Bmw 750li
Will be attempting this project tomorrow....first i shall check for blown capacitors....
  #97
Old 09-22-2015, 12:51 AM
well I took apart the amp and the capacitors appear fine....bought the wrong multimeter so couldn't check the capacitance readings.
The amp chip mod has arrived....looks like a scary job
  #98
Old 09-23-2015, 11:03 AM
attempted the chip mod and replaced some capacitors...now my left bass worked and right did not. as the amp heated up all kinds of shyt started to go haywire.
  #99
Old 09-26-2015, 05:14 AM
Verberne Verberne is offline
Mein Auto: BMW 735i
Can someone tell me which one of the 2 is the left bass in the first picture posted in this Thread. Is it like you see left is left bass and right is the right bass?
Thank you
  #100
Old 09-26-2015, 12:57 PM
That would have been useful information to me as well. I put a video up on youtube...not the best but at least you get some idea.
HTML code is Off
