Headlight Washers - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 01-25-2005, 01:32 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2018 540i
Question Headlight Washers
I did a quick search, but didn't find anything.
The manual states that when the headlights are on and you activate the windshield washers, the headlight washers are also activated. I thought I had read somewhere that the headlight washers only come on if you hold the windshield washer lever for a few seconds. I used my windshield washers for the first time in the last week after the snow and although I only briefly pushed the washer switch, it appears the headlight washers activated because I saw several pulses of spray coming over the hood.
Is there supposed to be a delay before the headlight washers start spraying? If not it seems weird. I don't like the fluid spraying all over the place. (My prior C240 had a separate switch for the headlight cleaners)
BMW-CCA
Bimmerfest Supporting Member
Current: 2018 540i MSport | Med Blue/Cognac| MSport Brakes | Multi-Contour | HK | ZLP
Prior: 2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather
Old 01-25-2005, 02:36 PM
JonathanIT's Avatar
JonathanIT JonathanIT is offline
Padawan
Location: L.A., but I'd rather be on Brokeback Mountain
Mein Auto: 2004 330ci Convertible
Sorry I can't help you but I just have to say... boy I'm glad I don't have headlight washers!
--J.
2004|330ci|Convertible|Silver Grey Metallic|Sport Package|Premium Package|Steptronic|NAV|Xenon Adaptive Headlights|Heated Seats|Black Montana Leather|Aluminum Brushed Column Trim|SSR/GT3 19" Rims (original 18" Style 71's in storage)
Old 01-25-2005, 03:27 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
If you are really quick, you can get a wipe and not get the headlight or windshield squirt... If you want a squirt on your window, 90% of the time you'll also get your headlights... but it only does it the first time you wash your window (with headlights on) and then every 5th time after that, IIRC...
I really like my headlight washers... they are actually required in Europe if you have Xenons...
Anyway, hope that helps...
Old 01-25-2005, 04:42 PM
markl53's Avatar
Well, the manual did mention something cryptic about "reasonable intervals", so maybe that was their way of saying every 5 times . I literally pulled the wash lever for a split second but that's all it took for the headlight washers. OK, I'll try it again -- at least it seems they won't come on every time. I was thinking of shutting off the headlights for a second to disable the headlight washers and avoid the overspray.
BMW-CCA
Old 01-25-2005, 05:46 PM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
--J.
Yeah, the large nmber of posts complaining about this feature caused me to order heated seats instead of hte cold weather pac.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
The Ultimate Tanning Machine
Old 01-25-2005, 09:07 PM
markl53's Avatar
That's funny because I was torn between the 2 alternatives. I surmised from the '05 brochure that the rear armrest only came with the folding rear seats and my sales person wasn't 100% sure so I went ahead and got ZCW instead of just the heated seats.
BMW-CCA
Old 01-25-2005, 10:03 PM
Double Vanos's Avatar
Double Vanos Double Vanos is offline
Former ZHP pilot
Mein Auto: 2011 135i M Sport
Yeah just press them slightly and it wont set off the headlight washers. A little practice and time and you will get this down in no time.
2011 135i M-sport ,6 speed, coral red, HK and ipod.
Old 01-26-2005, 07:06 AM
Using SPF 45
You're a lot more likely to use the ski pass-through in a sedan than I figured I would be in my cabrio.
Old 02-22-2007, 07:59 PM
gordo325xiwagon's Avatar
gordo325xiwagon gordo325xiwagon is offline
Urban Knucklebuster
Mein Auto: '01 325xit & '93 300zx TT
I wish my headlight washers would work. Anyone have a trouble shooting sequence?
__________________________________________________ ___
2001 325xit & 2012 328i Sportwagon - Evolution of the Brand
Old 02-22-2007, 08:49 PM
GerWil GerWil is offline
Mein Auto: 2016 340i & 2014 X1
Wink
I live in Vermont and own a 2006 Passat with xenon lights and head light washers. We were about to by a second 2007 model, and discovered almost by accident that the head light washers were no longer available, even with the Xenon lights. I believe they are a necessity with these lights. We then started to look at BMWs, and now have a 335xi on order for ED in May; because of the headlight washers .
Old 02-23-2007, 11:13 AM
Salvator's Avatar
Livin' like Larry!
Not to be snarky, but I assume you have your headlights on? The washer won't work otherwise... and if you have auto-headlights, and its not dark, it may not consider them "on" as well...
Are you the original owner? Perhaps a previous owner disconnected them... Are the little doors popping open and the sprayers are sticking out, but just not spraying (turn on headlights, and have someone wash you windows while you stand in front of the car and look at the little trap doors below the headlights... if they don't pop open, either they are disconected or they are not getting the signal from the switch...
Old 02-23-2007, 06:07 PM
AzNMpower32's Avatar
Tar Heel Faithful
I just hate how much fluid the washer system consumes if you use the headlamp washers. Even with the gigantic tank on the X3, the low washer fluid light comes on too much during the winter time with all the road spray. It got so bad on our trip to Montreal, that if there were no cars around me, I'd turn the headlights off for a split second, hit the windshield washer, then turn the headlights back on to bypass the headlamp washer because the low fluid light was on. The road grime was so bad that not washing would have been dangerous, but I was already low on the precious fluid (with no Canadian Tire around until the next day).
Old 02-24-2007, 10:18 AM
Urban Knucklebuster
Originally Posted by Salvator View Post
I assume you have your headlights on? ...
Are you the original owner? Tturn on headlights, and have someone wash you windows while you stand in front of the car and look at the little trap doors below the headlights... if they don't pop open, either they are disconected or they are not getting the signal from the switch...
I am 2nd owner. I'll check it out this weekend. gordo
Similar Threads
? for peeps with headlight washers. Double Vanos 3 Series & 4 Series 12 11-15-2004 07:35 AM
ok, the headlight washers can make a mess, but are they useful? Magna General BMW Questions 20 02-17-2004 03:12 PM
Headlight Washers lsedels 3 Series & 4 Series 15 10-28-2003 12:07 PM
Detailing headlight washers Keith(UK) The Detail Department 4 03-18-2002 06:05 PM
