Ground Straps F30 - Bimmerfest - BMW Forums
Old 03-25-2020, 06:50 PM
F30 MSport F30 MSport is offline
Mein Auto: F30 BMW 3 series 320i M s
Ground Straps F30
Hi All
I have just been having some issues with slow crank and starting and have ruled out a bad battery and alternator, all read well on multi meter when ignition on and off.
I have just changed the Ground strap that is located near the front of the exhaust and understand that there is a second strap on the passenger side under the engine?
What splash guard do I need to remove to get visibility of this one?
Old 03-26-2020, 09:00 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
How old is the battery?
Old 03-26-2020, 09:41 PM
The battery is fine, I have tested the voltage on both stationary and idle and both are god readings, which means it is also unlikely the alternator too.
I really just want to know if anybody can tell me where the second, if any ground strap is. I have replaced the one at the base of the exhaust, so looking for the one that is supposed to be under the engine
Old 03-27-2020, 04:54 AM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
Check the TIS - perhaps it mentions it. https://www.newtis.info/tisv2/a/en/
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 03-27-2020, 03:58 PM
Thanks for that. I'll check it out
