E85 / E86 Z4 (2003-2008)
E85 Z4 Roadster, E86 Z4 Coupe, E85 Z4 M Roadster, and E86 Z4 M Coupe talk with our BMW gurus here. |
Front strut and rear shocks
I just replaced the front struts and rear shocks on my 07 . Replaced with stag struts , noticed the ride height is much higher. Is this normal? Also I still hear a clicking noise on the front when going over bumps at slow speed what could this be? Any help would be appreciated
Sponsored Links | ||
Advertisement | ||
If the Stags are nitrogen charged, then they do tend to sit a bit higher initially. Generally most will settle a bit after some driving. WRT to the clicking, need to check to ensure the center nut that holds the strut rod to the strut bearing is fully seated and tight. They can be hard to get tightened and any gap between the mount and the shoulder on the strut rod, even just a few thousandths of an inch will cause a click or clunk.
Sent from my iPad using Bimmerfest
Sent from my LM-X210(G) using Bimmerfest mobile app
Advertisement | ||
Sent from my LM-Q710(FGN) using Bimmerfest mobile app
Cisco Camacho
1973 Porsche 2.0 Money Pit in Chrome Yellow 1995 BMW 318Ti - Black Saphire Metalic 2006 BMW 750Li - Black Saphire Metalic |
Had the same problem with a different brand. Mine were adjustable (ride height). Problem was the locking rings. "Wrench tightening" was not good enough (came loose). Once they tightened with a wrench, I had to use a screw driver (or equivalent) and hammer to further set. No problem since then.
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Stuck Rear Strut Mount | barleymanz | E39 (1997 - 2003) | 9 | 04-07-2018 12:46 AM |
* M6 * - Press Release from BMW | Emission | E63 / E64 M6 (2006 - 2010) | 6 | 03-06-2007 08:20 AM |
Volvo/Evolve at SEMA | BlackChrome | General Automotive Forum | 12 | 11-16-2004 10:31 AM |
