E85 / E86 Z4 (2003-2008)
E85 Z4 Roadster, E86 Z4 Coupe, E85 Z4 M Roadster, and E86 Z4 M Coupe talk with our BMW gurus here. |
Valve Cover Bolts
I have a leak in my 2003 z4 2.5 valve cover gasket. I plan on replacing it my self as there are many good threads and videos on this. I am having a problem finding the bolts as they are "one time use" When I do a search I find bolts for 2006 or newer, will these fit my car or where can I find the right bold (I cannot find the part number)
Also if any one has a suggestion on a kit or store to buy from it would be appreciated. Thanks Tom |
Sponsored Links | ||
Advertisement | ||
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness. (The Works of George Santayana p. 65) Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it. |
It's only the aluminum torque to yield bolts on the N52 engine used in 2006 and later models that are one time use.
The steel studs on your M54 engine are reusable. You do need to be careful about overtightening them and snapping them off. Should that happen, here's the info on replacements. http://bmwfans.info/parts-catalog/E8...er_head_cover/ Quote:
Advertisement | ||
Thanks for the info - I hope I do not need extract broken bolts - fingers crossed. I am going to replace the plugs while I am there - is there anything else I should do while I am doing this?
Tom |
Yes...do the Vanos seals and the eccentric shaft gasket also. And while you are there, do the oil filter housing gasket next door. I just did all this. Took me a day, but she is sealed up nice now.
Second that suggestion on the oil filter housing gasket since it is likely the same age as vcg. You may never notice it leaking until you lose your alternator (ask how I know..)
Depending on your mileage you might think about doing the vanos, but that's a more advanced DIY than the VCG. It's a 2003 with the M54 engine. There's no eccentric shaft so no sensor gasket to worry about.
I got the valve cover off and changed the plugs. I did break the vc exhaust hose. Ordered a new hose looks like a PITA to get at the lower connection. Also have the stuff do the VANOS. I do not have any signs of issues and wondering after reading the threads on removal (cutting bolt thread, jacking engine or pry bar on frontengine cross frame). I am really considering not doing the VANOS, concerned I my end up breaking some other parts. Car has 85k
![]() Anyway, how did it go doing the valve cover gasket? Were you okay reusing the bolts? I did not purchase any new ones either. |
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
N62/E65/E66 Valve Stem Seals Replacement, Valve Cover and Timing Chain Case Gasket | Knight's Master Tech | 7 Series DIY | 21 | 04-23-2018 09:32 PM |
DIY - E65/E66 - Valve cover gasket (driver side) | flash_n | 7 Series DIY | 28 | 07-08-2017 11:41 PM |
Putting timing covers after a retime m62TU | berkeleydojah | E39 (1997 - 2003) | 6 | 04-04-2017 11:15 PM |
Do the valve cover gasket yourself they said... | event3horizon | E90/E91/E92/E93 (2006 - 2013) | 5 | 07-11-2016 09:17 AM |
Valve Stem Seals, Valve Cover and Timing Chain Case Gasket Replaced (Chicago Area) | Knight's Master Tech | 7 Series - E65 / E66 (2002 - 2008) | 9 | 08-28-2015 04:50 AM |
