What are these? - Bimmerfest - BMW Forums
Old 05-26-2016, 06:41 PM
03SlvrZ4 03SlvrZ4 is offline
Mein Auto: 2003 Z4 3.0i
What are these?
I've looked on google, this forum and think the two pieces on the trunk might be luggage racks that have missing horizontal pieces. I've only had the car a couple of days, so I'm not sure. It's my 2nd Z4 but I am in the process of catching up on this forum and refreshing this old brain of mine.
Thanks for your help.
_a__a2_
Old 05-27-2016, 05:52 PM
sudoer sudoer is offline
M54 for life
Mein Auto: 04 Z4 3.0
It's for the hideous luggage rack.
Old 05-27-2016, 05:54 PM
Thanks ... that's what I was afraid of. I guess my next task will be how to take them off and what kind of body work will be needed once I get them off.
Old 05-28-2016, 05:50 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Interesting, it seems to me that the rack is mounted backward. I thought the "lip" should be at the rear to prevent luggage from sliding off during acceleration.
Old 05-28-2016, 05:58 AM
I don't have the rack itself, just the mounts. You are right though, that rack is mounted backwards. I never noticed it. Now to find out how to take the rack mounts off as I would rather have a "clean" trunk.
Old 05-28-2016, 09:07 AM
I must have been brain dead when I typed replies in this post. I knew from the time I saw them they would be screwed onto the trunk and once that trunk was open, the nuts holding that rack would be accessible with ease. How stupid could I be?? I'll so some further searching on the internet to see if there is a temporary fix if I take those brackets off and then have a good auto body shop fix the holes in the trunk. Would you leave them on in the meantime or take them off?
Old 05-28-2016, 07:34 PM
bwitherel's Avatar
bwitherel bwitherel is offline
Mein Auto: 2006 Z4 3.0si
You could do color matching bumper plugs as short term fix. Bumperplugs.com. They will match car color.
Old 05-28-2016, 07:35 PM
bwitherel's Avatar
I would remove them for sure
Old 05-29-2016, 08:38 AM
Bucko521's Avatar
Bucko521 Bucko521 is offline
Proud Canadian, I'm Sorry
Mein Auto: 06 Z4 3.0i & 01 Z3 2.5(2)
The rack is mounted correctly. The lip is on the forward side to prevent luggage moving forward into the seat area upon hard deceleration. This is for safety, and not a 'they put it backwards thing. The same/similar rack was used on the BMW Z3 as well.
01 Z3 2.5i Sapphire Black, 01 Z3 2.5i Topaz Blue(SOLD), 06 Z4 3.0i Jet Black
ZSCCA Area Rep and Member - Prairie CruZers
Old 05-30-2016, 07:05 AM
GeorgeT's Avatar
I guess it only matters if you are afraid of losing your luggage fro it sliding off the back or having it crash through the headrests/roll bars.
Name:	Rear Lip Mounting (2).jpg
ID:	565208   Click image for larger version
Name:	Front Lip Mounting.jpg
Old 05-30-2016, 01:15 PM
With the sponged bottoms of the rack I assumed there might be some adhesive that would pull up with the rack mounts. I had all the nuts and washers off and thought a small tap at the bottom of the mount bolts would be just enough to loosen the adhesive and they would pull right off.
The rack did not move.
I then had a wild thought maybe they added some permanent adhesive on that bottom of the mounts and IF I were to keep taping with the hammer to break that permanent adhesive how much paint would come with it?
So I attached the washers and nuts, tightened them back down and will find and read what my next option will be. I am calling the dealership tomorrow to see just how those mounts are attached and what will come off when I take them off.
Old 05-31-2016, 09:02 AM
BostonB6's Avatar
BostonB6 BostonB6 is offline
Mein Auto: 2005 E85 Z4 3.0
In case you need it, used trunklid for sale. It's even silver.
http://www.ebay.com/itm/like/3220420...&ul_noapp=true
Old 06-01-2016, 06:32 AM
