Convertible Top fabric Replacement - Bimmerfest - BMW Forums
Old 07-30-2018, 01:23 AM
Skeep Skeep is offline
Skeep
Mein Auto: 328xi
Our top has begun to get skid-marks on it pretty well so that it won't be long we'll be opening it up to the elements. So, have been perusing the replacement top, fabric only, mind you.
I've been looking at this vendor: https://www.autotopsdirect.com/BMW-Z...-Tops-s/55.htm
Have any of you any experience with this vendor or another with whom you've been quite satisfied? I would like to be able to install the thing myself, so am not looking to head down to the BMW garage and have them get me one from Munich and put it on at their leisure. Well, I'm very close to Munich now, probably could wander up there and get one....not.
Let me know if you've had some experience with this or another, thanks!
Her car--Z4 3.0si 2006 Her Sports Car (BMW Trained)
His car--328xi Sport Wagon 2009 Man Car (Motorcycle Trained)
Old 07-30-2018, 07:02 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
That's where I bought mine. Installed it December 2016 and still in good shape. I did the lift cylinders also while I had everything apart. Here's the vert top DIYs that cover the top replacement, the lift cylinder replacement, and other top related DIYs.
https://www.bimmerfest.com/forums/sh...&postcount=114
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 07-31-2018, 11:08 PM
Skeep
Mein Auto: 328xi
So, I presume the directions are clear and obvious to follow for a Neanderthal like myself and the tasks are not too complicated? The site gives the impression of being rather clear. Product guarantee looks solid. I think I see a winter project ahead.
DC, on another front, for those of us with lighter tops, we found that over the years the rubber components do rub off on the top making the tan top look pretty worn over time. Guess we might consider a black top?
Old 08-01-2018, 06:14 PM
dc_wright's Avatar
That'd be one approach to it. My car top was charcoal gray so I just went with a black to. Can hardly tell the difference.
Old 08-01-2018, 07:22 PM
gpraceman gpraceman is offline
Mein Auto: '06 Z4 ///M Roadster
Come time to replace my tan top, I will definitely go with black.
2006 Z4 ///M Roadster - Interlagos Blue/Beige
Old 08-08-2018, 09:27 PM
Skeep
Mein Auto: 328xi
PS: thanks for the PDF's from Shipkiller, I glazed over that posting due to my moving from SC to Italy....so am now finally getting my head re-attached. Thanks much for the advice and files. I am sure doing the top will be less of a head-ache due to that knowledge base!
Old 08-09-2018, 08:47 AM
X5M5 X5M5 is offline
Official Bangle Hater
Mein Auto: '01 X5 4.4i, '00 M5
Please post your results and any tips if you would not mind, as my top is getting a little worn and a re-freshening wouldn't be a bad idea.
Chris
'01 X5 4.4i Topaz Blue/Black, '00 M5 Anthracite/Red, '06 Z4M Red/Black, '05 Acura RL White/Tan, '12 X6 3.5i
Chris
Old 08-10-2018, 09:58 PM
Skeep
Mein Auto: 328xi
Hey Chris, sure. When I get to it will prob be winter. I'm having to sequence my fleet for various repairs and alterations, so it's on the calendar up ahead. I've also been studying Shipkiller's PDF series in prep for the change out.
Old 08-11-2018, 08:44 AM
dc_wright's Avatar
In addition to the new top canvas and head liner, there's a series of installation kits you need also that come from BMW:
Tension cable kit 54347119628
Headliner kit 54347110761
Without these kits you won't have the proper size pop rivets to reinstall the headliner and tension cables. You have to drill out the old pop rivets to remove one end of the tension cables and the headliner is held to the "B Pillar" area of the top frame with pop rivets.
Also, you'll need a pop rivet tool and you'll need to modify it slightly so that the head will fit into the channel when you pop rivet the holding pieces of the top canvas to the side supports.
ID:	811984   Click image for larger version
ID:	811986   Click image for larger version
