Front strut and rear shocks - Bimmerfest - BMW Forums
Old 02-04-2019, 07:15 AM
Mplawman Mplawman is offline
Mein Auto: 2007 bmw z4
I just replaced the front struts and rear shocks on my 07 . Replaced with stag struts , noticed the ride height is much higher. Is this normal? Also I still hear a clicking noise on the front when going over bumps at slow speed what could this be? Any help would be appreciated
Old 02-04-2019, 10:57 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
If the Stags are nitrogen charged, then they do tend to sit a bit higher initially. Generally most will settle a bit after some driving. WRT to the clicking, need to check to ensure the center nut that holds the strut rod to the strut bearing is fully seated and tight. They can be hard to get tightened and any gap between the mount and the shoulder on the strut rod, even just a few thousandths of an inch will cause a click or clunk.
Sent from my iPad using Bimmerfest
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-05-2019, 06:41 AM
Andyz4 Andyz4 is offline
Mein Auto: 2006 Z4 3.0si
Also make sure all 3 stress bar fasteners are good and tight, especially the one near the firewall. If not you will hear knocking/clicking over bumps.
Sent from my LM-X210(G) using Bimmerfest mobile app
[SIGPIC]
Old 02-06-2019, 02:42 PM
fcamacho fcamacho is offline
Mein Auto: 750Li
Sure the clicking isn't a bad CV joint? Constant clicking, maybe more in turns, indicates bad CV joints.
Sent from my LM-Q710(FGN) using Bimmerfest mobile app
Cisco Camacho
1973 Porsche 2.0 Money Pit in Chrome Yellow
1995 BMW 318Ti - Black Saphire Metalic
2006 BMW 750Li - Black Saphire Metalic
Old 02-06-2019, 08:05 PM
dc_wright's Avatar
Noise started coincident with install of the struts/shocks and is from the front.
Old 02-11-2019, 06:02 AM
Z4530i Z4530i is offline
Mein Auto: Z4 3.0si
Had the same problem with a different brand. Mine were adjustable (ride height). Problem was the locking rings. "Wrench tightening" was not good enough (came loose). Once they tightened with a wrench, I had to use a screw driver (or equivalent) and hammer to further set. No problem since then.
Similar Threads
Stuck Rear Strut Mount barleymanz E39 (1997 - 2003) 9 04-07-2018 12:46 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
Volvo/Evolve at SEMA BlackChrome General Automotive Forum 12 11-16-2004 10:31 AM
