Changing e85 6 Speed Manual Trans Fluid - Bimmerfest - BMW Forums
Old 11-12-2019, 05:08 AM
Gregory_tolson Gregory_tolson is offline
Mein Auto:
I purchased a 2003 Z4 M54B30 a few months ago and it has around 83k miles on the clock. I'm not sure if the 6 speed manual trans fluid has ever been changed. Should I go about changing it? Or will more harm be done since if it has the original fluid its been 16 years? Does it matter if I'm potentially changing it this late in the cars life? I've heard of bad things happening to automatics if the fluid is changed with a lot of miles.
Old 11-12-2019, 08:41 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
When you change it, make sure you loosen the fill plug before draining.
Old 11-26-2019, 02:14 PM
joelselman joelselman is offline
Mein Auto: 05 Z4 3.0i smg, 01 530ia
You're fine to change it on a stick. The fear of late in life change is for automatics only although I've changed several late in life and had no problems. Make sure you use the correct synthetic oil...pretty sure your stick shift takes atf.
