2000 E39 M5 idle hunting and a ton of error codes! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 05-06-2019, 06:22 PM
luke1574 luke1574 is offline
Mein Auto:
I have a 2000 e39 M5 i bought almost a year ago. Ive been slowing working on it just minor things here and there. I recently changed the spark plugs and changed my oil seperator system (the seperator system didnt do much to help oil burning) and replaced my mass airflow sensors. Everything was running fine till half of my cylinders stopped firing (which is why i replaced my sensors) and that fixed the problem for about a day. After replacing them my car was idle hunting for a bit until warm then it went away, now it does this constantly but for some reason drives smooth. I decided to scan it today and i was blow away by the amount of codes that appeared out of no where. I was given P1526 Manf Cntrl veh. spd. idle speed control auxiliary imputs. P0022 Camshaft Position actuator A - bank 2 timing over retard. P1350 manufacturer control ignition system or misfire. P0316 misfire detected first 1000 revs. P1432 manufacturer control auxiliary emission controllers. And last but not least P0175 system too rich (Bank 2). Normaly i would look up common fixes and start to tackle them but this is just so many i didnt know what to to or where to start. My car has about 130k miles on her. Im not sure what else to do and i figured id ask if anyone had any ideas on here before going to the mechanics.
Old 05-10-2019, 06:02 PM
CLMurguia1 CLMurguia1 is offline
Mein Auto:
My boss's 01 e39 M5 is doing the same thing. Codes for O2 sensors, 02 heaters, misfire on all cylinders, thermostat, tank leak. 17 codes in all. What caused it on yours?
Old 05-11-2019, 06:32 AM
marcozandrini marcozandrini is online now
Mein Auto: 2018 M240i
OP, go to bimmerforums and post your issues in the ”general bmw mechanical help” forum. Hopefully bmwdirtracer will respond. His name is Chris and he tracks the same car. Chris is a top flight tech. There are other great techs there also.
Old 05-11-2019, 01:27 PM
Mein Auto:
Originally Posted by marcozandrini View Post
OP, go to bimmerforums and post your issues in the "general bmw mechanical help" forum. Hopefully bmwdirtracer will respond. His name is Chris and he tracks the same car. Chris is a top flight tech. There are other great techs there also.
Thank you i will!
Old 05-11-2019, 01:31 PM
Mein Auto:
2000 E39 M5 misfiring and lots of error codes
I have a 2000 e39 M5 i bought almost a year ago. Ive been slowing working on it just minor things here and there. I recently changed the spark plugs and changed my oil seperator system (the seperator system didnt do much to help oil burning) and replaced my mass airflow sensors. Everything was running fine till half of my cylinders stopped firing (which is why i replaced my sensors) and that fixed the problem for about a day. After replacing them my car was idle hunting for a bit until warm then it went away, now it does this constantly but for some reason drives smooth. I decided to scan it today and i was blow away by the amount of codes that appeared out of no where. I was given P1526 Manf Cntrl veh. spd. idle speed control auxiliary imputs. P0022 Camshaft Position actuator A - bank 2 timing over retard. P1350 manufacturer control ignition system or misfire. P0316 misfire detected first 1000 revs. P1432 manufacturer control auxiliary emission controllers. And last but not least P0175 system too rich (Bank 2). All of the fixes ive been able to find are for if your car is giving you a cylinder code Normaly i would look up common fixes and start to tackle them but this is just so many i didnt know what to to or where to start. My car has about 130k miles on her. Im not sure what else to do and i figured id ask if anyone had any ideas on here before going to the mechanics.
Old 05-11-2019, 10:06 PM
MoparJim MoparJim is offline
Mein Auto: 1967 Barracuda convert
First guess would be that the parts that you replaced were not of great quality, but that's just a guess.
Old 05-16-2019, 09:39 PM
ard ard is offline
Resident Curmudgeon
you need your own code reader.... a BMW specific reader, like the foxwell nt520
just 'reading codes' means you are seeing EVERY code since the last time they were reset. Could be years old.
Reset/clear, then see what comes back.
OEM is not what BMW sells
Similar Threads
730d Hunting Idle rc822 7 Series - E65 / E66 (2002 - 2008) 0 12-28-2018 02:16 AM
idle hunting and fuel quality merlintiaga E60 / E61 (2004 - 2010) 5 08-15-2014 04:44 AM
2000 528i BMW engine hunting problem SilverEagle E39 M5 (1998-2003) 0 06-25-2012 06:57 AM
1989 E34 525i (M20 Motor) - Idle Issues Hunting Idle iheartdelsols E34 (1989 - 1995) 3 10-04-2010 05:28 AM
328i Hunting Idle help silverbmw528 E36 (1991 - 1999) 9 10-16-2006 01:04 AM
