E93 catalytic converters - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 05-10-2019, 05:12 PM
JLHoodJr JLHoodJr is offline
Mein Auto: 2010 M3 Convertble
The warning light on 2010 M3 came on saying “excess emissions” and have engine checked soon. I took it in and both catalytic converters registered over .9 on the emissions test. The dealer doesn’t work on them, but instead replaces them - for the modest cost of $7000 (not a typo). The service advisor said to have a muffler shop take a look at them as they can usually repair them. I’ve not noticed any effect on the motor’s performance. Two questions, are replacements really that expensive? And can they really be cleaned out so they’ll function?
Old 05-14-2019, 05:01 AM
Jon Pappas Jon Pappas is offline
Mein Auto: 08 BMW M3 Convertible E93
Not sure how strict TX is with emissions but you may want to consider removing the cats. Another option is to go with high quality high flow cats (Active Autowerke has the pair for ~$1700).
Current ride: 2008 BMW M3 Convertible (E93)
Old 05-14-2019, 04:22 PM
Thanks. I live in El Paso which is a non attainment area under the Clean Air Act, so it’s pretty strict. I’ll check Autowerke.
Similar Threads
E90/E91/E92/E93 E92 e93 e60 e61 e88 e82 m3 (every single part you need) available oem parts! Alexz0521 Parting Out 23 10-09-2019 10:19 PM
Can a muffler be damaged from replacement of the catalytic converters?! Gnova General BMW Questions 2 03-26-2019 01:20 PM
46A4 - DDE: DeNox Catalyst, Understanding root cause serge1 X5 E70 (2007 - 2013) 20 04-27-2018 12:53 PM
Where do we find the list of all E39 transmission, airbag, abs & obd BMW error codes? arthurwood E39 (1997 - 2003) 21 12-08-2017 05:39 PM
High flow catalytic converters ? Fulltone74 E39 (1997 - 2003) 7 02-23-2007 03:34 PM
