Instrument Panel Bulbs?? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > E24 (1976 - 1989)
E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989.
Old 04-01-2012, 04:32 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I removed the instrument cluster from my '88 635 today to upgrade the 3W bulbs to 5 W in order to make the panel brighter at night. I replaced the bulbs with Sylvania 2825 bulbs and they seem to work fine. I also wanted to replace the 4 smaller bulbs at the bottom of the panel, one for the light switch, one for the fog light switch and 2 for the bottom of the instrument panel. I bought Sylvania 74 bulbs as they looked just like the ones in my car but they would not work. They are 1.4W. If anyone knows which bulb will work please send me a PM or post it. Thanks.
COL(Ret), US Army
Hagerstown MD
2019 X5 MSport 40i
2016 Corvette Stingray (Fun Car)
2016 528ixdrive/MSport (Ret)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 04-04-2012, 07:18 PM
rmorin49's Avatar
A fellow on the bigcoupe board told me that the bulb I need is a 2721(Sylvania bulb number). I bought 4 today and hope to try and install them this weekend.
Returned the 2721 bulbs for a higher wattage (2.2) 2723 bulbs. Still hope to install this weekend.
COL(Ret), US Army
Hagerstown MD
2019 X5 MSport 40i
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2011 335d (Ret)
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
Old 04-22-2012, 05:41 PM
bgriff bgriff is offline
crapshooter
Mein Auto: (2) '85 6ers, (1) '79 6er
Instrument panel bulbs
Hey Rmorin49, I don't want to open a can of worms about you changing from 3W to 5W bulbs, however, I did this same thing on one of my '85 6ers a year or so ago - it just made sense, since my closeup vision isn't quite what it used to be. I caught so much crap from some of the bigcoupe guys about the 5W bulbs generating too much heat, at least more than the 3W bulbs, the 5 watters were brighter, but because of the additional heat in the instrument cluster, I went back in and switched the bulbs back to 3W. I didn't have problems with the 5W's, I used them for maybe a month and I don't drive this car much at night anyhow, however, I didn't want to cause a possible problem with too much heat in that cluster....the new 3W's seem to be bright enough now, maybe because they're new and the old 3W's were a little dusty. Might be good to get some opinions from the guys who've been there, done that.
Good luck with it, your 6er looks great, by the way.
Bob G
Old 04-22-2012, 09:49 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Smile Dash bulbs
As is the case with most bulbs as they age, Dash bulbs glass will go blackish and so cutting down the light output, Another tip which concerns a lot of single contact bulbs, If you compare a new bulb with an old one you will see that the solder contact on an old bulb will be considerably smaller than a new one which can and will cause the bulb to become loose in it's holder. Peter
Old 05-14-2019, 06:20 PM
irbydk irbydk is offline
Mein Auto:
Can I replace the instrument panel bulbs with LED bulbs? where i can find it ?
thank you!
Old 05-14-2019, 09:11 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
Welcome to Bimmerfest!
Yes, you can replace SOME of the IC bulbs with LEDs. The large ones that illuminate the cluster. Take one out and take it to the auto parts store. Most of them have a good selection of LEDs in various base configurations.
Quotes to live by:
Ken Kanne, Silverhill, AL, Bimmerfest Site Moderator
BMW-CCA #441426
1993 325is M3 clone"Ashlyn"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette";1995 318is"Bebe"
HTML code is Off
