Very Slight jerk or hesitation at highway speeds 2004 320i - Bimmerfest - BMW Forums
Old 05-15-2019, 01:04 PM
torontomike torontomike is offline
Mein Auto: 318i
Hey Guys, I feel this very slight jerk or hesitation at highway speeds on my 2004 320i. It's very subtle, happens every few minutes on say a 45 min trip, so subtle but I can feel it. It seems to lessen the longer I drive at approx 3500 rpm's. I'm thinking maybe I need to replace the air filter or maybe the spark plugs are dirty or the transmission oil needs to be replaced, thoughts? Much appreciated!
P.s. it is a 5 speed manual stick with 240K km or 150K miles
Old 05-15-2019, 01:10 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
torontomike: have used a scan tool...any codes? could be a lot of things...need to eliminate some things...I'd start by cleaning...once I had a similar problem a I replaced the spark plugs and then coils. but that was a shot in the dark.
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 05-15-2019, 02:48 PM
Mein Auto: 318i
Hey thanks for getting back. I don't have a scan tool to be able to read codes. Any recommendations on where I can get one? But I have a feeling what you said could be it, the spark plugs, I don't think I've changed them in over 5 years for sure!
Old 05-15-2019, 03:10 PM
BeeemerBro
Remember it could be a multitude of other things but the plugs (and coils) why not at this point. You still will not be full circle complete but change out the battery (group#49) and ground straps... especially if you live survive in a harsh climate region of the country...I had my heart broken (and wallet) due to those deteriorated/ corroded ground straps. I made my own and now every X3 has new fresh ground straps.
Old 05-16-2019, 11:14 AM
Cruncher55 Cruncher55 is offline
Mein Auto: 330Ci, 911 & Wrangler
A buddy had a "yaw" sensor go out on him ('03 330). The car would jerk every so often while driving (as opposed to sitting at a light - haha). It's part of the DSC system; I think was applying slight brake pressure to separate wheels making the car jerk a little.
It was an expensive fix, in the $1,300 range. The part online is north of $700, so hopefully it's a much cheaper problem.
Good luck.
Similar Threads
Does going past the redline damage your engine while upshifting? 2004 320i torontomike E46 (1999 - 2006) 7 09-20-2014 03:22 PM
Hesitation at speed 2004 325i glgpc E46 (1999 - 2006) 1 04-04-2008 02:50 PM
Slight shutter or vibration at high speeds...could it be a tire? jetstream23 E46 (1999 - 2006) 9 12-18-2006 04:48 PM
Slight hesitation after cold start kalemkea E90/E91/E92/E93 (2006 - 2013) 11 11-04-2005 05:13 PM
Whistling noise at part throttle- highway speeds. bmw325 3 Series & 4 Series 10 02-12-2002 03:48 PM
