E60 545i thoughts - Page 2 - Bimmerfest - BMW Forums
Old 06-03-2018, 02:34 PM
Burning2nd's Avatar
Burning2nd Burning2nd is online now
Under the lift arms
Mein Auto: e39, e83, e60
over heated warped head yeah its happened...
but even when a head over heats you can get it to run..
I don't understand, either the valves are shot and your not getting compression or the rings are shot and your not getting any compression..
the valves will have a distinct sound when cranking, and the rings can be soaked...
can you make a video, camera sitting on something about 5 feet away, hood opened.. cranking the motor.. id like to hear it
Specializing In Breaking Things Professionally
15486372<-----
Old 06-03-2018, 02:47 PM
bimmer7410 bimmer7410 is offline
Mein Auto: 2003 540i
Its not quite what you asked for, but I have a couple endoscope recordings from a few days ago:
Ive already made progress in taking apart pieces to get to the valve covers (all spark plugs, coils, intake, many electrical connectors, etc) so I'm not sure its in cranking condition atm.
Old 06-03-2018, 04:10 PM
Burning2nd's Avatar
Under the lift arms
yeah that sounds like no compression
i didn't realize you took it apart already..
let us know what you find
15486372<-----
Old 11-21-2018, 01:38 PM
Finally had some time to cut off a couple stripped bolts that caused me to pause the project a couple months or so back.
Pulled off the passenger side valve cover and immediately found that the damned timing chain isnt even on the camshaft! No wonder theres no compression
Wont have time to see whats up on the passenger side today, but damn this an interesting failure mode. I have yet to see any other posts with this happening.
On the upside, there is no sludge buildup from what I can see insofar.
Old 11-21-2018, 05:17 PM
Burning2nd's Avatar
Under the lift arms
Let us know how you make out.. you know what you gotta do.. Just decide which way you want to go..
15486372<-----
Old 11-26-2018, 11:40 AM
So I'm now at the point where I can remove the heads soon. Ive seen via TIS that you have to remove the exhaust manifold on each side to remove the heads. Any tips on doing this? Youtube is sorely lacking in certain details here
Old 11-27-2018, 04:43 AM
Gonzalo1495 Gonzalo1495 is offline
Mein Auto: E63 645CI , Audi TT 225
Drop the sub frame
Old 11-27-2018, 01:57 PM
Burning2nd's Avatar
Under the lift arms
you dont have to drop the sub frame to take a head off of a m62 Or n62...
BUT you did have to take the exhaust off and drop the header out thru the bottom
Bentley page 180-23 and 24
15486372<-----
Old 11-27-2018, 06:57 PM
Roger that, ill take a look when additional tools arrive
Old 11-28-2018, 01:41 AM
Burning2nd's Avatar
Under the lift arms
If the timing is already removed.. and the head is still connected but the head is loose,
refasten the head bolts hand tight.. then move to the manifold bolts on the head.. loosen them.. then go down under and to the flange last...
15486372<-----
Old 11-28-2018, 05:40 AM
The head is tight. I have the car on jack stands currently. So you say I dont need to lower subframe to get to exhaust manifold, just loosen the top then go in from the bottom? Sounds good.
Old 11-28-2018, 05:41 AM
Burning2nd's Avatar
Under the lift arms
makes no mention of subframe to remove a head
15486372<-----
Old 11-28-2018, 05:44 AM
Roger that, appreciated.
Old 02-28-2019, 10:36 AM
So, some small progress:
After searching and contemplating the results for weeks, I purchased an engine from eBay: Link
Decided against trying to look into and fix the current engine as its likely toast anyway (0 psi in multiple cylinders, timing popped off driver side cams gear, broken cam lobe spring observed on passenger side, etc..who knows what the hell happened to this thing)
Engine is said to have ~100k mi
Now the question is what should I go ahead and take a crack at while I have the engine on the stand? What I have so far on my mental list:
1) Valve cover gaskets
2) Oil pan gasket, upper and lower
3) Coolant pipe
4) Valve seals
I know there are more items I may be missing. Definitely dont want to miss anything that would be easier fixed outside the engine.
Old 02-28-2019, 02:06 PM
Annolago Annolago is offline
Mein Auto: BMW E60 545i
Clean secondary air injection pump air path on the backside of the engine.
Old 02-28-2019, 04:11 PM
Good catch, almost forgot about that one
Old 02-28-2019, 10:04 PM
H F H F is offline
Mein Auto: 2005 545i
Purchase the AGA hook tool since you have the engine out . It will be easier to clean the secondary air channels in the exhaust valve cavity. This is where the carbon builds up , as carbon blows out and clogs the air ports ..
Old 03-01-2019, 07:23 AM
Also one ive read about. Added to the list
Keep em comin'
Old 05-15-2019, 01:11 PM
Semester has FINALLY ended and I have time + a little cash
Getting ready to put the new(to me) engine on a stand. I see that the transmission bell housing mounts with M6 bolts. This seems too small imo.
Can anyone point me in the correct direction
Old 05-15-2019, 01:40 PM
oldiegoodie oldiegoodie is offline
Mein Auto: 2007 550i 6MT
Isn't there a secondary air delete kit available for the N62B44?
Sent from my SM-G950W using Tapatalk
2007 E60 550i Sport 6MT
Old 05-16-2019, 10:16 AM
bump..i know someone knows this off the top of their head
Old 05-17-2019, 09:52 AM
For future reference in case anyone else has this question: Found the bolts to mount the N62: a mix of M8 and M10 screws. 80mm should do it, strength rate of at least 8.8
Ill likely create a new thread for keeping track of the rebuild/install process
Old 05-17-2019, 06:54 PM
TexasMu TexasMu is offline
Mein Auto: 545i M6
I'll be following along
Old 05-20-2019, 01:36 PM
H F H F is offline
Not sure if there is , but it would be nice . but here in California passing smog would be an issue ..
