Engine Code help? - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 10-21-2019, 10:17 AM
evanswan's Avatar
evanswan evanswan is offline
Mein Auto: 2015 BMW 750i
Engine Code help?
x5m reading this code. Have power loss of 60 hp or more.
Ever heard of- Auxiliary coolant pump for charge air cooler: Dry-running detected.
Also have Engine DME2 Ladeluft-Kuhlsystem, leistungsreduzierer Betrieb: Kuhlmittelverlust durch Kuhlmittelpumpe2. Charge air-cow system, power-reducing operation: loss of cowling agent due to cowling agent pump2
Rancho Mission Viejo, CA.
BMW X5M F85
Old 10-21-2019, 10:30 AM
M5f10_ M5f10_ is offline
Mein Auto: M5 f10
check your turbo coolant level, check it when engine is cold. Not hot.
Skickat från min iPhone med Tapatalk
Old 10-21-2019, 11:04 AM
evanswan's Avatar
Checked
Empty on left side. Bone dry. Thank you
BMW X5M F85
Old 10-21-2019, 11:17 AM
Mein Auto: M5 f10
That is why it detects and you dont have power sometime.
Fill it up, drive it, whait until it engine is cold. open up, and repet until it is on normal level the coolant for the turbo chargers.
And look very often so it does not drop low becuase it can be something else that it is loosing the coolant.
Good luck
Old 11-02-2019, 01:12 PM
evanswan's Avatar
So two weeks later some of the powers back but not all. Tested for leak no leak of coolant to the turbo. But car is still not as much power as it had and I can tell the exhaust note and some lag happening to the throttle response areWondering if damage might've been caused to something when the cool one empty
BMW X5M F85
