Fluid dripping when i start the car - Bimmerfest - BMW Forums
Old 02-26-2018, 12:42 PM
alpinef30zh alpinef30zh is offline
Mein Auto: 17 f30 318i
Like a few minutes ago i started my car, put it reverse and started reversing and i noticed something is dripping, the AC wasnt on. It rained today but there is no way that could be related to the issue since it happened alot on sunny days too i wanted to make a post about this but i just kept forgetting
Im not sure whether its water or oil since i didnt take a closer look at it
Should i be worried or is this normal?
Old 02-26-2018, 05:13 PM
bmwexpat bmwexpat is offline
Mein Auto: 328I
Chances are it's water but you need to confirm. Next time you backup and see fluid park your car and do the following:
1. Put a finger in the fluid and then rub the finger with the fluid against your thumb. Does it feel wet like water and there is some drag on your fingers when you rub them? If so it likely water and no big deal.
2. If you think it's water do a sniff test of you fingers. No smell it water. If you pick up a sweet smell it could be antifreeze. If that the case keep an eye on your cooling system to see if you have leaks or your coolant level drops in the reservoir.
3. You rub your fingers and the fluid feels very slick and or you see a color or residue on your fingers. If so that means you have some type of oil or other lubricant leak. This could be something very simple such as a faulty drain plug crush washer or some other gasket that may have a minor leak.
Hope that helps.
Old 02-26-2018, 05:19 PM
Hope that helps.
Thank you so much for the reply really appreciate it , i will make sure to check it once its not raining and the runway is dry.
Old 02-27-2018, 07:53 AM
I checked it today and it seems like its water nothing sticky, just normal water with no smell to it, so that means nothing is wrong with the car?
Old 02-27-2018, 10:02 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
OP is in Israel. It's hot there. 99.99999% certain it is condensation from the A/C system and TOTALLY NORMAL
Current BMW's:
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2018 340i RWD 6MT MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
