headlight! - Bimmerfest - BMW Forums
Old 09-19-2018, 07:31 PM
dinogt4guy dinogt4guy is offline
Mein Auto: 2008 Mercedes E350 sport
headlight!
So I replace the high beam in the Z4 last week, all was good. This week the low beam goes out! So I go and get a bulb and replace it, I thought it came on for a sec but not sure, but it definitely isn't working! Could it be the igniter? Never dealt with one of those before? Troubling shooting ideas? Or just order an igniter and see if it works?:
Old 10-11-2018, 09:29 PM
Scalpel_Boy Scalpel_Boy is offline
Mein Auto:
You should have an igniter (starter) only if you have a xenon (HID) headlight. In US version Z4s Xenon headlights the high and low beams are the same bulb. If you have two separate bulbs for high and low beams and an igniter you may have European headlights (xenon + halogen). In either case if your bulbs are burning one after the other check the wiring harness inside the headlight assembly. The insulation is probably gone (common problem) causing shorts.
Instead of ordering parts you may not need use the igniter and or bulb of the opposite working side to test first.
Old 11-11-2018, 08:10 AM
ghyde ghyde is offline
Mein Auto: 325 Ci 2005
Also, open the black port cap on top of the headlight unit and there are three thin wires: red, green and black. These three wires connect into a black rectangle connector, which is plugged into the red igniter. Look carefully for cracks in the wire coating and for broken wires. It is apparently common for these three wires to break - I have solders several back together, but now searching for wire replacement ideas and
And please pass along any wire replacement ideas, parts links, etc. Thank you.
