Help needed - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 01-07-2018, 01:10 AM
uke6050 uke6050 is offline
Mein Auto: bmw m5
Help needed
Hi I have a bmw e60 m5
Problem I'm having is car is going into limp mode
Read fault codes with snap on diagnostics and also inpa along with dis
The fault code which keeps coming back is 27da 2b57 2796
I believe 2b57 and 2796 are there because car is in limp mode
I turn car off and back on limp mode gone but comes back
Anyways I done some research my code was 27da plausibility,brake booster, vacuum pump.
So I went ahead and replaced the pressure sensor and vacuum pump the ones beside the brake booster but still have same symptons same fault
I'm thinking to change the relay behind glove box next the relay for vacuum pump
I have a few questions for yous
Any suggestions on what it could be
I've heard you can run a full vacuum test using inpa and dis
Any instructions on how this could be done
Any info/help very much appreciated
Regards
Sent from my SM-G925F using Tapatalk
Old 07-03-2018, 02:06 PM
M5gaz M5gaz is offline
Mein Auto:
Hi, did you ever get this issue sorted?
I'm having same problems and car has been unusable for months now***x1f649;
Gaz
