2006 m5 smg transmission problem - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 04-11-2019, 12:59 PM
KevinX KevinX is offline
Mein Auto: Pontiac
I have a 06 M5 with SMG tranny. The car was first having problems not seeing the proper gears. Found the wiring to the sensor strip once repaired again having bare wires. We took the tanny out and removed the sensor strip. To remove it we had to remove the solenoids. Meaning we open up the hydrolic system. I repaired the wiring and we put the tranny back in. I ran the bleeding of the system with ISTA. Checked the fluid level and seen it was good. The car wouldn't go into gear. i followed the procedure of adapting the tranny since we took it out without replacing anything. It adapted the clutch fine but when i went to adapt the transmission it fails. It gets to 5th gear then times out everytime. Now all i get is this error. The car was basically fine before we took it out. I see the pump is making 35 psi. and the accumulator making 96 bar. To me its not shifting the gears. Is their another way to bleed the system. Is their something common that happens when installing the tranny back in that stops the tranny from shifting? Fork sticking? slave cylinder damaged? All ISTA says is to adapt the system but again the Teach in Transmission always times out.
Similar Threads
Rear Speed Sensor problem to Transmission Jgbrannan 7 Series - E65 / E66 (2002 - 2008) 19 09-14-2018 01:56 PM
A purist review of SMG II nate General BMW Questions 30 03-25-2013 05:47 PM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 07:20 AM
update on smg problem - bmw corp response bear 7 Series & 8 Series 8 11-25-2005 01:11 PM
M5 Official Press Release Emission 1M & M2 2 07-12-2004 09:43 PM
