weird occurance - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 01-29-2020, 08:22 AM
SteveinArizona SteveinArizona is offline
Mein Auto: BMW 530e
weird occurance
Yesterday I got in my car and started driving and realized that the steering wheel was still in the raised position blocking my view of the HUD. So I tried to use the control switch to move it and it wouldn't move. I even tried shutting off the car and starting it up again and it still didn't move.
I decided I had to call my SA the next day for a fix. But this morning, when I started the car, it worked fine.
Probably just a gremlin at work but wondering if anyone else had a similar issue.
Steve
Old 01-29-2020, 11:16 AM
RangerWalker RangerWalker is offline
Mein Auto: 2017 BMW 540i
I've had the experience where the steering wheel stays in the up position, blocking the view of the display. If I press the seat memory button it moves back into desired position. But I haven't had an issue with the steering wheel control switch being unresponsive.
2017 540i - Bluestone
2014 535xi - Black Sapphire
2011 535xi - Black Sapphire
2008 535xi - Monaco Blue
Old 01-30-2020, 05:41 AM
Mein Auto: BMW 530e
That didn't occur to me. If it ever happens again, I will try that.
Thanks.
Steve
Old 01-30-2020, 05:27 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: M550i, 540M-Sport, Scud
My old E39 started doing this about 12 years ago. Took it to the dealer and they said the up/down motor assembly needed to be completely replaced to correct the problem. The cost was breath taking, so I live with it. Pressing the seat memory button or the wheel control lever will return it back to position. But seat memory brings it to my desired position without thinking about it. Still does this once or twice a month for all these years. If you are under warranty, I would demand a fix if it occurs again.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 01-31-2020, 07:36 AM
guyinacar guyinacar is offline
Mein Auto: 40e
Next time, get video. Just in case.
Old 02-02-2020, 05:36 PM
ExGMan's Avatar
ExGMan ExGMan is offline
Mein Auto: 2019 530ex
It has happened a couple of times in my 2019 530ex. Stopped happening after two trips. If it happens again, I'll expect the same. NBD.
John Gamel
Chestnut Hill, MA
2019 530ex
2015 R1200RT
BMW CCA - 2006 - present - Ombudsman
BMW MOA - 2009 - present - Consumer Liaison
