Ordered an M4 today, winter tire question - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 10-01-2016, 04:34 PM
Stevenym4 Stevenym4 is offline
Mein Auto: M4
I ordered an M4 cab today with the competition package. The car comes with 255/30/20 tires I believe. I have access to a set of rims and tires from an M3, 5 lug, 120 mm bolt pattern, 17 in. x 7.5 in., 41 mm offset. The tire size is 225/45/17. I realize there is about an inch difference in height which will cause a slightly lower speed to register on the speedometer. My question is will the 17" wheels from the M3 work on the M4 without causing issues with the car and will they fit over the brakes? I did not get the carbon brake package. Got 5.3% off invoice for those who are interested ordered as follows:
Old 10-02-2016, 06:51 AM
Asteroid's Avatar
Asteroid Asteroid is offline
Don't be a left lane hog
Mein Auto: M2
No advice on your tire question. I just wanted to say how cool it was that you checked off almost all of the boxes!
F80 M3 ED Nov 30 2016- Southern Italy and Sicily
F31 328xd ED Dec 2 2013- Compliance pix
E82 135i ED Sep 18 2008- Delivery pix
E61 535xi ED Aug 31 2007- ED Report--N. Italy
E90 330i ED June 26 2006- ED Trip Report
"Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac?"- George Carlin
Old 10-02-2016, 07:33 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
No; minimum wheel size is 18" in the F8x.
BMW OEM Audio PnP integration
www.TechnicPnP.com
[email protected]
Old 10-02-2016, 07:49 AM
Mein Auto: M4
Ok thank you
Old 10-02-2016, 08:30 AM
visi107 visi107 is offline
Mein Auto: 2016 M3
As was said previously, the 17's will not fit, has to be minimum 18. In addition to that, not all 18 inch wheels will fit.
Also whatever setup you go with, you want the height, diameter and circumference to be about the same or you will run into issues with the traction control. It's not just about the speed being off. It is recommended that the circumference is within 2-3% of the stock sizes.
2018 F80 M3 CS
My 2016 M3 ED adventure
2013 328i X drive - retired
Old 10-02-2016, 08:42 AM
Mein Auto: M4
I greatly appreciate the advice. I'm going to be using the car to go between ny and Florida over the winter. I may just leave the stock tires on and plan trips to happen between snow storms. I was thinking I'd buy snow tires, install them then ship the stock tires to Florida to be installed once I arrived. After thinking about it, it sure seems like a lot of effort. If I have to make an unplanned trip back to ny during a storm I'll just fly back.
Does anyone think the brake upgrade package is worth getting?
Old 10-05-2016, 02:04 PM
[email protected] mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Congrats!!
