Battery registration DIY - Page 5 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series DIY
7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners
Old 06-08-2016, 10:40 AM
oneredspyder oneredspyder is offline
Mein Auto: BMW 328i xdrive
Battery
The BMW dealer wanted $500 for the battery change and computer update. I did it about 4 months ago and 5000 mi, drove from Boston to Clearwater last winter. No problems
Old 06-12-2016, 09:24 PM
leondb leondb is offline
Mein Auto: 1968 Firebird
There is an adapter you can plug into cigarette lighter plug with 9 volt battery that will keep memory powered while changing battery.
Never used one on a BMW but can’t see why it wouldn’t work.
  #103
Old 06-23-2016, 02:11 PM
Born2Fight Born2Fight is offline
Mein Auto: 2007 BMW 750i
Battery replacement
Originally Posted by roy couch View Post
What did the dealer charge??
Hello Roy,
Dealer, here in TX, quoted me $338 + $15 core + $160 for registration for my 07' 750i E65. Needless to say, I replaced mine with AdvanceAutoParts' Autocraft AGM Battery and registered myself with INPA for about $185 total.
  #104
Old 06-23-2016, 03:24 PM
Sircas Sircas is offline
It's the Machine in Me!
Mein Auto: 06 M6, 94 840CI & 88 M3
Born2Fight,
Where can I get the INPA software & hardware for the registration?
Thanks,
  #105
Old 06-23-2016, 06:34 PM
Originally Posted by Sircas View Post
Born2Fight,
Thanks,
Sircas,
I got the INPA cable off ebay few weeks ago and it came with the software dvd. I also got a cheap pc with windows 10 off craigslist for $110. PM me if you need help with your car, although, I'm not very mechanically inclined.
  #106
Old 08-28-2016, 01:10 AM
Where/How on the Carly BMW app?
  #107
Old 08-29-2016, 06:55 AM
Originally Posted by AntDX316 View Post
The easiest way to battery registration is to use the Carly BMW app.
Carly for BMW doesn't have option to clear the Battery Registration code. I emailed the developers and was advised that the feature will be coming soon.
  #108
Old 08-29-2016, 10:36 AM
Cool! Are u already gone! If so good luck!
Rod McCaster
  #109
Old 08-29-2016, 10:39 AM
Doug Huffman's Avatar
Nuclear engineer
Beyond registration of the new battery, deletion of the old battery's charging adaptations is required. Otherwise the charging system/IBS will charge the new high capacity battery like it did the old wore out battery, and kill the new one even faster.
  #110
Old 08-29-2016, 01:52 PM
Rod McCaster
Yes,
I'm in NJ area and sorry we couldn't install the battery in your car on time.
  #111
Old 09-30-2016, 10:17 AM
tony750 tony750 is offline
Mein Auto: BMW 750 LI
I was quoted $410 installed at BMW dealer. That seems high to me??
  #112
Old 09-30-2016, 01:52 PM
Rick in Yuma's Avatar
Rick in Yuma Rick in Yuma is offline
Mein Auto: 05' 760li,94' H1,08'Smart
Batteries can be purchased at AutoZone or Pep Boys for about $190.00. You can find an independent shop to register the battery for about 35 to 50 bucks. It takes all of about 15 minutes to put the battery in the car. 30 if you don't know what you're doing. I'll let you do the math, and tell us, if you think your being ripped off.
  #113
Old 09-30-2016, 02:16 PM
The math is simple, $240 compared to $420!! DON'T need a calculator to figure that out!!
  #114
Old 02-26-2017, 06:26 AM
BimmerKais BimmerKais is offline
Mein Auto: 745iL
So the engine was completely removed from my car a couple of weeks back for almost 8 days as valve seals replacement and few other critical fixes were needed. In this case engine along alternator and harness was disconnected from the battery.
Now do i have register the battery again? In my case, battery wasnt removed from the car nor the terminals were removed from the battery. However, warning 'recharge your battery' comes up very soon if the ignition is left in ON position. (in a matter of 5 mins max) i would say.
The battery i have has worked perfectly since last year it was replaced. Its not original BMW battery. But has 110ah
I wondering if i register it now, would the power module take it as a new battery? Hows INPA gonna know if its a non BMW battery with different power figures?
  #115
Old 02-27-2017, 01:12 PM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
Yes I would, it's only a 15second process
  #116
Old 03-22-2017, 06:33 AM
ksnurr ksnurr is offline
Mein Auto: 2004 745 li
2004 745 Li stuck in 3rd plus many other warnings
where do i get the software and cables to register my battery??
  #117
Old 03-23-2017, 06:26 AM
where do i find the program to register my battery, also what type of cable do i need to interface my computer with the car??
  #118
Old 03-26-2017, 12:43 PM
davidr540ihelp davidr540ihelp is offline
Mein Auto: 1998 740il
I have a question about this battery registering, l have a 1998 740il and have changed the battery, when I bought the car it had a reconditioned battery in it that was bad , I changed it to
an after market battery and my question is does this year model have to be registered as well?
  #119
Old 03-26-2017, 05:06 PM
I do not know for sure but I do not think the computers in 1998 were as sophisticated as 2011. I do not know when they went over to the programming for the battery. I used a Carly with a blue tooth hook up to do my 2011 328i battery switch.
  #120
Old 04-14-2017, 07:03 AM
Iv;e made some progress but am looking for some advise. I managed to reset my computer and get my care out of tranny fail safe using diagnostic tools i aquired. i monitored the valve body solenoids while driving and observed 1,2 and 3 actuating while the care shifted. 4 never turned black or on. so shifting to fourth never actuates and car goes back into tranny fail safe. i then used the activate feature F6 i believe to manually activate the solenoids, 1 through 3 work shile 4 just says shift lock. Do you think i am looking at a bad solenoid? And is there a way to reset shift lock on solenoid 4 or program to shift from 3 to 5 skippin 4rth like an older tranny would do automatically? Thank you very much for any advise anyone can give as i have NO ONE within 70 miles who can look at this car. being stuck in 3rd gear i dont think i can drive it there.
Using the diagnostic tools i also found two codes related to the tranny. 004F89 EGS ration monitoring 3-4/0051AD no message, receiver EGS, transmitter DSC.
still have ABS cannot find it listed to reset manually. and have dynamic control issue with a code that calls out wrong type speed control modual on left rear tire, these do not seem related.
any thoughts would be greatly appreciated.
Ken
  #121
Old 06-13-2017, 01:31 PM
olesh999 olesh999 is offline
Mein Auto: Alpina B7
will this work on f01 (2009-2015)??
