**NEW** FOR 2018 VARGAS VTT N54 GC LITE **2.0** N54 Turbos - ON SALE!!! + FREE SHIP! - Bimmerfest - BMW Forums
Looking to get some great BMW parts for your car? Get the latest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 04-15-2018, 04:30 PM
[email protected] mike@n54tuning is offline
Mein Auto: 07 335, 15 M3
N54 "GC LITE 2.0" Stock Location Turbochargers (Fits All N54 Models)
Product Code: VTT-GCLITE-1
DISCOUNTED ORDER LINK
https://www.n54tuning.com/vtt-n54-gc...54-models.html
WHP Level supported (with proper fuel, upgrades, and tuning) Stock-700WHP
All New design for 2018! We are proud to introduce the latest in our line of N54 turbocharger products the VTT "GC LITE" 2.0 turbochargers. This is a new N54 turbocharger from the ground up, using 100% new parts throughout. Taking a page from our wildly successful GC line of N54 turbos we now off the "GC LITE". This turbocharges uses a high flow 9 blade TD04L turbine coupled with a 16T billet compressor wheel for flow capability of 700WHP. This allows spool faster than anything else on the market, rivaling the spool of stock N54 turbochargers, and comes with massive power potential. If the ultimate driveability is what you are after, without sacrificing top end power. The " GC LITES" are the upgrade for you!
Some of the groundbreaking features are fully new turbocharger from the compressor housing to the bearing housing, to the turbine housing, we had them engineered to fit in the stock N54 location, but provide the full flow of a much larger turbo. Every part on these turbos were designed around our specific goals for power, flow, and reliability. What we ended up with is a turbocharger, that can utilize the stock location while providing enough flow for 700WHP. To do this we increase the area inside not only the manifolds, but also the turbine, and compressor housings, we also slightly increase AR ratio on the turbine housing to free up even more flow, while not giving up anything in spool. To put it bluntly, there is no other 700WHP capable turbocharger option on the market single or twins that can match the spool, ease of fitment, power or reliability of our "GC LITE" turbochargers!
Upgraded thrust: Every set of stage GC turbos comes with a performance upgraded thrust to extend the life of the turbochargers.
Billet Compressor wheels: 16T Billet compressor wheels are used to maximize flow per shaft revolution
Turbine housing is cast from 22+NB Stainless steel
VTT Inlet, AN/OR Charge pipe bundle. The GC turbochargers work perfectly with our very own VTT 2" inlets, and VTT silicone HOT SIDE charge pipe, and were designed to be used with these pieces. If you already have inlets, or want to use another inlet brand that is no problem, simply do not add them to the drop down. These turbochargers will only work with our silicone charge pipes currently, if you have already purchased one for you stock frame turbos, it can be reused on these if you remove the adapters, simply remove the charge pipe from the options. (Please note, if you remove these options, and do not have these items, you will not be able to install the turbos, as the stock inlets, or charge pipe will not fit the new turbos)
We also offer 2000 degrees ceramic coating for the ultimate it under hood heat reduction, and to help aid in spool! Please choose from the options if you want your turbo coated!
JB4 N54/N55 On Sale!! Free Shipping - M3/M4 JB4 and Downpipes on Sale - Evolution Racewerks Charge Pipe on Sale - ER Charge Pipe with Tial BOV in Stock and Ready to Ship - ER FMIC - BMS DCI!
Old 04-24-2018, 12:25 PM
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
Old 05-11-2018, 12:20 PM
Mike
Old 05-23-2018, 08:05 AM
Bump for a great deal @ www.n54tuning.com
Lowest Prices on the FORUMS!!
Mike
Old 06-12-2018, 11:28 AM
Mike
Old 06-23-2018, 07:42 PM
Mike
Old 01-28-2019, 11:14 AM
Mike
Old 02-09-2019, 11:30 AM
Mike
Old 02-24-2019, 03:15 PM
Mike
Old 03-21-2019, 02:04 PM
Mike
Mike
Old 04-06-2019, 02:37 PM
Mike
Old 04-18-2019, 06:29 PM
Mike
Old 05-15-2019, 02:21 PM
Mike
Old 06-06-2019, 02:26 PM
Mike
Old 06-20-2019, 05:43 PM
Mike
Old 07-11-2019, 09:34 AM
Mike
Old 07-16-2019, 08:46 AM
Mike
Old 08-12-2019, 04:21 PM
Mike
Old 09-13-2019, 07:13 PM
Mike
Old 09-20-2019, 08:18 AM
Mike
Old 10-11-2019, 04:05 PM
Mike
Old 12-10-2019, 08:49 AM
Mike
Old 01-09-2020, 08:33 AM
Mike
Old 01-16-2020, 08:59 AM
Mike
