Belt Tensioner DIY Without Removing Fan??? - Bimmerfest - BMW Forums
Old 09-19-2019, 09:52 AM
paramedic1079 paramedic1079 is offline
Mein Auto:
Is it possible to replace the belt tensioner and idler pulleys on the N55 engine without removing the fan? Any recommendations are greatly appreciated. Thanks.
Old 09-19-2019, 10:01 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
The fans are pretty easy to remove on the E70. Why not just take it out rather than risking damage to the fan?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 09-19-2019, 10:05 AM
Mein Auto:
I agree with you. I was just curious if anyone has tackled this without removing the fan. My indy wanted 1.5 hours labor but I've done this before on my E90 3 series so I figured it was worth a DIY.
Old 09-19-2019, 10:23 AM
I have changed belts on my E70 N62 without removing the fan but I was very careful and had done it a few times. Not easy and definitely a strain because of how hard you have to push on the wrench. The tensioner is probably much easier to remove and replace but the belts are a hassle with the fan in.
Old 09-20-2019, 06:41 AM
deroy deroy is offline
Mein Auto: X5 e70 4.8
If you decide to take the fan out, release leftover excess pressure in the coolant expansion tank first, before you detach that small tube that runs to it from the top of the radiator, and put a piece of cardboard behind the radiator for protection too. As ‘taco said, you have to wrench with some force.
Verzonden vanaf mijn iPhone met Tapatalk
Old 09-20-2019, 09:25 AM
jason0 jason0 is offline
Mein Auto: x5
I have removed the fan several times on my N55. Never removed any coolant tube. Is the 8 cylinder different?
Old 09-20-2019, 10:29 AM
This is what is being referred to on the V8. I think the fan can slide by it but if not it is super easy to disconnect and reconnect. I think the N55 inline 6 has a tube in a similar spot.
Old 09-20-2019, 05:01 PM
Mein Auto:
Thanks for the help. I'm going to tackle the job in a week or two.
Old 09-20-2019, 05:30 PM
It’s not bad. It’s an extra 10 minutes to remove the fan and place the cardboard in front of the radiator. Not a bad job.
