Hiding dashcam cables near side curtain airbags - Bimmerfest - BMW Forums
Old 04-03-2019, 07:44 AM
PRNDM/S PRNDM/S is offline
Mein Auto: 2017 330i Gran Turismo
I installed a two-channel dashcam with the front camera mounted high on the windshield, and I ran the following wires:
- the power cable runs from the ODB port in the driver's footwell, up the door trim, short exposed run across the dash, then behind the A-pillar up to the top of the windshield
- the cable to the rear camera runs from the front camera, across the top of the windshield to the passenger's A-pillar, under the A-pillar trim piece, then under the top door trim to the rear of the car
See the attached photo.
I didn't remove the A-pillar trim to run any of these wires; I just tucked them in with a plastic tool.
I read on BlackBoxMyCar that running the cables like this won't interfere with the side curtain airbags.
Anyone have any advice or known warnings about my setup? Thanks.
Name:	dash cam wiring.jpg
Old 04-03-2019, 09:17 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
Someone needs to visually confirm not guess that the cables are not positioned to interfere with bag operation.
Old 07-25-2019, 02:45 PM
xenopus xenopus is offline
Mein Auto:
Curtain airbags
I have just watched four BlackVue install videos that run the power (or rear camera) wires over the side curtain airbags, pretty much in the middle. One was from BlackBoxMyCar, even though they have another video saying they have never seen a problem.
If you look at the anchor points of the side curtain airbag, which starts behind the A-pillar trim and then runs up along behind the headliner, I would be concerned about airbag deployment interference.
I did not want to risk it, so on both my old F25 and new F25 I removed the A-pillar trim and ran the wires along the wire harness there, which is behind the airbag. If you assume the wire would break, I'm guessing you then would have the wire ends whipping about into your face when the airbag is going off. And if it doesn't break, then the airbag deployment path might be affected...
Similar Threads
E63/64 DIY: CIC Retrofit for BMW E63s - (Long and Pic Heavy) AlexMSFT 6 Series DIY 13 08-22-2019 10:40 AM
What package do the side airbags come in? November Rain 5 Series 1 10-16-2004 05:07 PM
Passenger Side curtain airbags popped out bluskye 3 Series & 4 Series 14 08-16-2004 06:56 AM
Servotronic steering and rear side impact airbags LC X5 E53 (1999 - 2006) 2 08-12-2004 05:48 PM
