i3 coding - Page 11 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 07-21-2017, 08:56 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by VeniceEight View Post
When you say:
"You only need to VO code."
Can you clarify that? Do mean add 6NS?
What am I missing?
You stated the following:
ALSO
Make all of these Aktiv except Single_or_Multilink. Make that Multilink.
You only need to add 6NS to FA and VO code HU_NBT. The only FDL coding you need to do is switch microphone back to one.
Old 08-03-2017, 04:02 PM
d451d d451d is offline
Mein Auto: i3
I just got my I3 back from the dealer. I had a check engine light and mold in the AC system. They must have updated my ECU since all my codes have been cleared when I got it back. I tried recoding using the E-sys , E-sys Launcher and PSzDLite Data that I used previously but the only CAFD that didn't throw an error was the HU_NBT. I was wondering if I could get the links to the latest and greatest E-sys software and PSzDLite Data files.
Thanks in Advance!
Dave
Old 08-03-2017, 04:08 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Thanks in Advance!
Dave
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 08-03-2017, 05:16 PM
Mein Auto: i3
Thanks Shawn,
I installed all the E-sys and PSdZData and I'm still getting the following errors and info while trying to read coding data. A couple work but most still fail. I attached a pic of what I am getting. Could the PSdZData be too new?
Dave
Old 08-03-2017, 05:18 PM
Thanks Shawn,
Dave
Doesn't Map to an Item means either Incorrect E-Sys Launcher Car Series Selected or Incorrect E-Sys Connection Target Selected.
Old 08-03-2017, 05:53 PM
Mein Auto: i3
Oh damn. I did use the wrong connection target. Question is if I made changes to items under the HU_CBT cafd under the F001 target, will they match up to the same items under the I001 target? Or should I reverse my mistake by loading the F001 and undoing those changes first?
Dave
Old 08-03-2017, 06:08 PM
Dave
The changes you already made are fine. Those ECU's mapped properly as they were common to both chassis.
Old 08-03-2017, 06:14 PM
Mein Auto: i3
Sounds good. I was worried that I might've caused a bit of mischief for my wife. She just took the car out to get some dinner.
Dave
Old 08-16-2017, 06:21 AM
heresy_fnord heresy_fnord is offline
Mein Auto: 2015 BMW i3
If the i3 truly has a 9 liter gas tank (2.37 gallons), why does the esys cheat sheet tell you to set the tank to _8 liter? I'm referring to the word doc sheet that is included in the "cheat sheet" folder with all the other cheat sheets.
3005. ***61664; TNK_LITER_REHCTS set to: mcv_rex_liter_kl_rechts
3005. ***61664; TNK_OHM_REHCTS set to: mcv_rex_ohm_kl_rechts
3005. ***61664; TNK_VOLL_ANZEIG set to: _8 liter size
Old 08-16-2017, 06:29 AM
God-Follower's Avatar
God-Follower God-Follower is offline
Achtung! Hochspannung!
Mein Auto: 2018 i3, F10 535d
There is no option for 9L, only 7L and 8L(and then up to over 20L).
I assume it is because the last liter or so of gas in the tank is unusable due to pickup screen limitations.
Sent from my ONE A2005 using Bimmerfest mobile app
Old 08-16-2017, 07:33 AM
Almaretto's Avatar
Super Moderator
It depends on year of car as to the tank size and whether coding is necessary.
Old 08-30-2017, 11:49 AM
jpeterferrell jpeterferrell is offline
Mein Auto: 2014 BMW i3
Hey Shawn, just picked up a CPO 2014 i3 and my coding cable - can you send me the most recent links to the E-Sys and PSDZData software. Does the current version run fine on the latest Windows 10? I plan to do the coding with my Surface tablet and an Ethernet to CAT5 adapter, hooked up to my coding cable of course...
Old 08-30-2017, 12:00 PM
Win 10 is fine. PM sent.
Old 08-30-2017, 03:04 PM
I'm not answering for Shawn, but I have the same hardware you're describing; I had no issue on my surface pro 3 with Windows 10 (creators update) using the USB to ethernet adapter.
Hope that helps for anyone else wondering.
Sent from my Nexus 6 using Bimmerfest mobile app
Old 09-14-2017, 08:53 AM
ekranoplan ekranoplan is offline
Mein Auto: i3
Any ideas if battery swap involves coding? Some German owners of 60Ah have upgraded to 94Ah but only through dealers. There are a lot of salvage i3s about. Seeing as only 5% of LiOn batts ar fully recycled (vrs >90% of Pbacid ones) makes sense to keep an older BEV or Rex going with newer battery - dealer option means the 60Ah goes back to BMW but DIYer could use it in the house.
Old 09-14-2017, 09:05 AM
Almaretto's Avatar
Super Moderator
Battery swaps always require registering to ensure proper calibration. If you change size, then coding is also needed.
Old 09-14-2017, 09:23 AM
The last time I checked this too, in America at least, the REX i3s were going to be excluded, at least initially. I had thought the battery swap program was years away?
Old 09-14-2017, 10:56 AM
Mein Auto: i3
Yes REx models didn't appear to be included in dealer swap.
It makes sense for BEVs in winter climates where range can go down quite a bit, especially if no heat pump fitted.
Any idea what might be needed coding wise? Disconnect HV power, remove plug and Air Con connection then the main unit drops out pretty easily (beware 250kg bulky item!).
Heat pump cars have different AirCon valve at battery pack.
Physical changes look simple enough - SOC/Max Kappa might show quite differently ?
Any recommends for sotware and diagnostics hardware?
Old 09-14-2017, 10:57 AM
Almaretto's Avatar
Super Moderator
E-sys, ENET, and ISTA+.
Old 09-14-2017, 11:11 AM
Mein Auto: i3
Many thanks.
Any recommended suppliers?
Are there chapters to look at on ISTA to perform calibration / balancing?
Old 09-14-2017, 11:14 AM
Almaretto's Avatar
Super Moderator
Many thanks.
You can get ENET almost anywhere (eg, Ebay, Amazon), but recommend someone with good seller rating.
For E-sys and ISTA+, you can get over in Coding/Programming Subform. There is getting started guide there as well and ISTA+ is especially very user friendly.
Old 09-14-2017, 11:36 AM
Mein Auto: i3
Many thanks!
Old 09-14-2017, 11:49 AM
Almaretto's Avatar
Super Moderator
Many thanks!
Old 09-23-2017, 04:44 PM
Uberschmutzer Uberschmutzer is offline
Mein Auto: 2014 BMW i3 Rex
I just had my 2014 i3 rex updated to the latest software and so I need to recode. Could I please get the links to the latest and greatest E-sys software and PSzDLite Data files that will work for this latest update? Thanks--
Old 09-23-2017, 06:16 PM
PM sent.
