Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 2 - Bimmerfest - BMW Forums
Old 08-07-2017, 07:35 PM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by tz693 View Post
I coded the Sport Display on my 2011 F10 535iX. It showed the units of kW for power and Nm for torque. When I floored the car, the torque meter maxed at 400 Nm which is about 300 ft-lb that matches my car's spec. Recently I coded the hp and ft-lb units for the Sport Display. However, when I floor the car, the max torque still reaches the the scale of 400 which now should mean 400 ft-lb. Am I missing something? Or the Sport Display is just imitative?
It is not very accurate.
Old 08-08-2017, 07:45 PM
tz693 tz693 is offline
Mein Auto: 2011 535iX BB
Thanks.
It looks like the ft-lb uses the same scale as Nm. Is it anyway to code the scale factor?
2011 535iX Black Sapphire
Michelin PS A/S 3+
Service Manual: www.newtis.info
Part: www.realoem.com
Old 08-08-2017, 08:08 PM
Almaretto's Avatar
Super Moderator
Thanks.
I know not anyway to adjust. It is hard coded in firmware.
Old 08-15-2017, 07:34 PM
heresy_fnord heresy_fnord is offline
Mein Auto: 2015 BMW i3
Any place to get the cheat sheets other than facebook? I don't have a facebook account. I really don't want to make one.
Old 08-15-2017, 09:10 PM
Almaretto's Avatar
Super Moderator
i3 is the only one with updated sheet on Facebook. Otherwise, links are posted and included with guides.
Old 08-19-2017, 08:18 AM
Post was about cheat sheets, finally found an updated one.
Old 08-19-2017, 03:17 PM
Almaretto's Avatar
Super Moderator
Here you are, though does not look like most up-to-date sheet. There are errors in BFD.
File Type: pdf BMW Coding Parameters - I01 - For i3 series.pdf (614.3 KB, 649 views)
Old 10-15-2017, 02:38 PM
sun1914 sun1914 is offline
Mein Auto: 2014 328i
Hi guys I'm COMPLETELY new to BMW let alone coding one. I was able to successfully code for Bluetooth audio thanks to the walk through and a YouTube video i found.
Now I'm looking to do the euro fog code. I have already cut the tabs to access the button and have found the code for it on the forum but im not sure how to go about it.
Once I connect to esys . I read FA. Save FA to create a backup. Then, i figure I find the fem bod and then what?? Am I changing values to match the code on the cheat sheet? If so, once I do that then whats next?
Any and all help would be appreciated
Sent from my SM-N950U using Tapatalk
Old 10-15-2017, 02:57 PM
Almaretto's Avatar
Super Moderator
FDL coding, including werte value changes, are discussed in guides.
Old 10-15-2017, 04:31 PM
Thank you for the reply.
The guides seem great for individuals familiar with the process. Which I am not, What steps do i take to find where to apply these new values an d how do I go about applying them? Is that something esys does automatically? Or do I have to do it ?
Thanks again.
Old 10-15-2017, 08:26 PM
Almaretto's Avatar
Super Moderator
Thanks again.
The guides are meant for getting started. They are step-by-step words and pictures outlining process.
Old 10-16-2017, 04:50 AM
kern417 kern417 is offline
Mein Auto: Rocket
Old 10-17-2017, 05:18 PM
Originally Posted by kern417 View Post
Video was exactly what I needed thank you Kern.
I appreciate the help guys.
Old 11-15-2017, 07:15 AM
apollo.ab apollo.ab is offline
Mein Auto: F15 X5 25 DX
good afternoon to all. I am using esys 3.28.1 with easys launcher premium 2.6.2.124. When I am at FSC Editor mode, the right window "Available Cheat Codes" empty. at the right bottom window "Unknown Error". When I am pressing button "Refresh" nothing happen. Meantime at directory "TokenMaster\E-Sys Launcher Premium\FDLCodes" there are cheat xml files. What can be done in such situation? Thanks in advance for reply
Old 11-15-2017, 07:46 AM
Almaretto's Avatar
Super Moderator
Your are in FDL-Editor? You should be using Launcher 2.7.1. Adjust memory settings, delete unnecessary Kiswb, and only choose desired authors.
Old 11-15-2017, 08:19 AM
Thanks for your kind reply. Sorry yes, its FDL editor. I have download launcher 2.7.1 but afraid to install it. As understand it will be necessary to have new activation cod from tokenmaster who disappear. I can't obtain activation cod for NCD/CAFD tool almost half of the year. Just remove all files except yours from directory and its start to work. Can you also advise please which file is the best fr f15 x5? hope its yours also how I can update it, as I cant download it from link at this chat.
Old 11-15-2017, 08:25 AM
Almaretto's Avatar
Super Moderator
You should not need new activation code unless you reinstalled windows. Yes, mine is best. Latest is always found at Github as linked.
Old 11-15-2017, 11:00 PM
Can you please advise how I can update launcher. Should I need to uninstal old version wia control panel of the windows and then instal new version, or I need to remove it some other way? Thanks for your reply
Old 11-16-2017, 04:47 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
Yes, uninstall old version via Control Panel first.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 11-16-2017, 07:47 AM
its funny but after installation of 2.7.1 its require activation cod. what to do now?
Old 11-16-2017, 08:33 AM
have use activation cod from previous launcher and it accept.
Old 11-19-2017, 08:34 AM
phattbam phattbam is offline
Mein Auto: 2017 BMW i3 REx
Hello, care to share the cheat sheet you have for your L01?
Old 11-21-2017, 02:06 AM
spiri439 spiri439 is offline
Mein Auto: X5 F15, Z4 E85
Hello,
Sorry if I am posting wrong here, but does someone has any news from tokenmaster, I sent him 3 emails but no replies, Thank You
Old 11-21-2017, 05:07 AM
Originally Posted by spiri439 View Post
Hello,
I traded emails with him yesterday, and 2 times last week.
Old 11-21-2017, 10:49 PM
Dear Almaretto, have found that your cheat sheet which is included in setup of the last launcher, is bigger size then the latest one as per link in this chat. Can you advise why?
