Fxx-/Ixx-/Gxx-series Coding: Getting Started Guides, Tips, & Cheat Sheets - Page 4 - Bimmerfest - BMW Forums
Old 12-10-2017, 11:19 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Super Moderator
Mein Auto: Test Vehicles
Originally Posted by SimonG75 View Post
Trying the ISTA+ but I'm stuck at 'Read out vehicule data', after clicking on 'Complete Identification', the connection manager is empty? I followed all the installation step from the guide ???
Is E-sys closed? Are you getting fallback IP in connection manager? Is car running?
Old 12-10-2017, 11:23 AM
SimonG75 SimonG75 is offline
Mein Auto: 328i xDrive 2013
Car is running, E-sys close and empty screen in connection manager (no fallback). I also got this message "The vehicle could not be identified. Please check the access to the vehicle and check whether the testing-analysis-diagnosis has been activated".
Old 12-10-2017, 11:27 AM
Almaretto's Avatar
Super Moderator
Try using Windows to repair connection. If that fails, let car rest and try later.
Old 12-10-2017, 11:32 AM
I'll try that... but the strange thing is that I tried to connect with E-sys and it's working, I clicked on read and it worked! you mentionned earlier to try to re-read and look for error... would it be clear that there are error or if I need to dig? The read process was instantanious and no error poped up.
BTW I really appreciate your help!
Old 12-10-2017, 12:42 PM
Ok, got it working... here's a screenshot of the fault list:
Old 12-10-2017, 01:28 PM
Almaretto's Avatar
Super Moderator
Attachment 729449
With E-sys, Read SVT and make sure DME has CAFD and not corrupt. The next thing to do after reading is to "Calculate Test Plan."
Old 12-10-2017, 01:31 PM
There's no CAFD in DME...
Old 12-10-2017, 01:33 PM
Don't know if this help :
Old 12-10-2017, 01:58 PM
Almaretto's Avatar
Super Moderator
Attachment 729465
Attachment 729473
I thought that might be the case. You must inject:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT => Left-Click on desired DME => Click on "Detect CAF for SWE" => Select the CAFD from your I-Level => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE.
Before selecting Code, make sure only ignition is on (engine should be off). If any other ECU's are missing CAFD, then you can do same procedure, but engine can be running on those.
Old 12-10-2017, 02:03 PM
Thaks... just did it for DME2 and all error are gone.
FEM_GW and GWS don't have CAFD... do I need to repeat the process for those since I don't have error anymore? I have that screen poping when I try to Detect caf for swe for the two others:
Old 12-10-2017, 02:11 PM
Almaretto's Avatar
Super Moderator
[iurl="https://www.bimmerfest.com/forums/attachment.php?attachmentid=729481&stc=1&d=1512943641"][/iurl]
You will not need one for that ecu.
Old 12-10-2017, 04:30 PM
Thanks, everything back to normal... You're the best !
Old 12-10-2017, 07:21 PM
Rliquori22 Rliquori22 is offline
Mein Auto: 2012 550i
My idrive is locked up from Carly crashing on me. Any tips ? Just loops the opening logo and turns black over n over
Old 12-10-2017, 07:24 PM
Almaretto's Avatar
Super Moderator
Code with E-sys and Diagnose with ISTA+.
Old 12-11-2017, 10:24 AM
No laptop , just have obd dongles (carly and elm327)
Old 12-11-2017, 10:29 AM
Almaretto's Avatar
Super Moderator
Carly may be able to minimally diagnose, but unlikely fix.
Old 12-11-2017, 10:30 AM
Carly says no ecu present under cic
Old 12-11-2017, 10:33 AM
Almaretto's Avatar
Super Moderator
ISTA+ will say similar or missing encoding if CAFD absent or corrupt. E-sys can inject.
Old 12-12-2017, 08:34 PM
taint fair's Avatar
taint fair taint fair is offline
Mein Auto: 2018 M3 ZCP
Did you get this fixed? Heard of someone having a similar issue with BimmerCode and they reset the idrive from the car and it seemed to resolve the issue. Almaretto is right that ESys should be able to clear it up though.
2018 //M3 | Black Sapphire | Black Merino | Competition | Executive | Driver Ass | CarPlay | DCT |
2014 328 M-Sport | Mineral Grey | Black Dakota | Premium | Lighting | Cold Weather | Driver Ass | Driver Ass Plus | HK Sound | Dynamic Handling | Tech Pkg | Alarm |
Old 12-15-2017, 10:46 AM
Nope. It won’t let me reset anything
Old 12-21-2017, 08:40 PM
taint fair's Avatar
I think you need to get a laptop and a cable. ESys is probably going to be the only way to fix this short of a trip to the dealer.
Old 12-22-2017, 10:37 AM
phuksi phuksi is offline
Mein Auto: X3 3.0
Here is one more tip that I have not yet seen on cheat sheets... To automatically activate reversing camera and PDC when car rolls backwards, go to PDC --> 3009 --> AKTIVIERUNG_RUECKWAERTSROLLEN --> set to aktiv.
-p
Old 12-22-2017, 10:47 AM
Almaretto's Avatar
Super Moderator
-p
Vehicle should, from factory, automatically enable when in reverse. Is your car rolling backwards in drive?
Old 12-22-2017, 12:00 PM
Mein Auto: X3 3.0
Yes it does turn the camera and PDC on automatically on reverse. This is for those cases that you want to roll back the car in neutral or if you had a manual stick. Maybe not that useful but ran into it.
A more useful function would be the PDC to turn on automatically in slow speeds when front is getting close to an obstacle.
-p
Old 12-22-2017, 12:03 PM
Almaretto's Avatar
Super Moderator
-p
You need parking module (PMA) for auto-PDC.
