Car not starting - is it a ground issue? - Page 2 - Bimmerfest - BMW Forums
Old 02-12-2019, 11:52 AM
MysticRob MysticRob is offline
Mein Auto: E61 535xi Deep Sea Blue
Originally Posted by safoo View Post
I checked the ECU box after towing the car home and (luckily) didn't see any signs of water entry there.
I had a tiny bit of water in the battery compartment that I will be looking at once the car is running again.
Likely the sunroof drain hoses.
The one thing I wasn't sure about : in the passenger side wheel well I cleared debris from the rubber spout that is there behind the liner and water gushed out. There are 2 sets of wires and electronic connectors in the wheel well area and it seems like they are in the way of any water that comes out of the spout. Any idea what these are and if they should be protected? I found it odd that electronics would be so close below the water drain spout. This is just above the dynamic drive valve block on passenger side wheel well.
I had the same issue with clogged spouts on both sides. Saw the wiring, and I think it was the ABS or brake pad wear sensors. Don't remember but either way, likely not going to be an issue till the cars are much older and possibly suffer from tape and wire sheathing issues. It's not like they're constantly wet, especially out here (though recent weather has been nuts, with another storm on its way tonight).
Do you have a 2nd key to use in start attempt? Might be something that simple.
It is 11yrs old after all.
http://www.fixya.com/cars/t24327303-...rt_tried_clear
2008 535xi E61 Touring Wagon / 110k Miles / Deep Sea Blue Exterior / Natural Brown Leather Interior / MHD Stage 1 91 Octane Tune / xHP Stage 1 Transmission Tune / xHP xDelete
Old 02-12-2019, 03:12 PM
Annolago Annolago is offline
Mein Auto: BMW E60 545i
Not to be an alarmist but most people seem to miss water around the ECU/e-box. Maybe due to the fact that water can get out of the plastic housing were the fan is attached. So my advice would still be to take the box and disconnect the cables to see inside the plugs. Seems to be the only way that find a tell tale of water, unless you want to look at the actual circuit board for water damage.
Old 02-14-2019, 10:44 AM
safoo safoo is offline
Mein Auto: 2008 550i
I had pulled off two connectors from one of the devices in the ECU box and the pins all looked clean without any signs of water in there.
Yesterday I tested the water drainage between the trunk and quarter panel and water was draining out from under the bumper. I could see it running behind the air vent that is there. I actually think the water leaks in through the air vent because I saw a tiny bit of water around it when I opened up the battery compartment the first time a couple weeks ago. I'm still looking for a DIY on how to take out the vents to replace.
I also removed the tail lights and the gasket looked clean and in place without any signs of water. I cleaned up the body where it makes contact and put a thin layer of vaseline to help reseat the gasket. I will do further tests once the car is up and running.
I will test the sunroof drains next. Note, I did not see any tube on either side of the trunk compartment - will check behind rear wheel well next.
Old 02-14-2019, 10:46 AM
Quick update on the thread. I have INPA installed and the cable now. I need to run the DME CAS sync and try to start the car. The voltage in the battery was low again, so getting it recharged now before I try it. I will likely replace it with an AGM battery since it is approaching 4 years old anyways.
I was reading I need to Code and Register the new battery. Does the Carly App handle both coding and registering?
Old 02-15-2019, 05:58 PM
zoom750 zoom750 is offline
Mein Auto:
Yes. Carly can do that.
Old 02-16-2019, 10:44 PM
I love the BMW community and it was a big reason why I bought a 5 series again. I want to thank everyone who replied in this thread.
My car finally started. It took a week for me to get INPA working on an old laptop and I was able to perform the EWS CAS sync (in German!) today. I put in a new 95Ah AGM Battery. Registered it with Carly App. The car initially didn't start, but I remembered the note from MysticRob and in Fred's link about the Fob possibly not working. So tried my 2nd FOB and finally started!
Summarizing the issue for future:
I think the Battery was the main issue all along (it was just under 4 years old) and I was able to get a Made in Germany 95Ah AGM battery for a really good price ($125) so I don't mind upgrading that. In hindsight, I should have started there first as I had the same issue in my E39 many years ago. Even then the auto stores all tested my battery fine. I plan to use a Schumacher battery maintainer once a week.
The multiple failed start attempts led to the EWS CAS sync code. I was able to get INPA installed to handle this. Now I have some diagnostics software and the cable. I'll retry getting an English version again. Also got the Carly adapter and app (~$140, but worthwhile investment)
I replaced a fuel pump relay that wasn't necessary ($40). Also replaced the crankshaft sensor ($100) - I don't mind the CPS one too much since it was 10+ years old.
I took care of clearing out most of the potential drain/water leak areas but will be making sure the rear quarter panel and sunroof drains are free and clear since there was some water in the battery area.
Lastly, I noticed the Battery Voltage (measured in Carly) was 13.9-14.1V at idle - is ~14V normal for an AGM battery or too low? Supposedly previous owner had put in a new Bosch alternator recently and forum opinions were mixed on this.
Old 02-17-2019, 12:55 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: e39, e60, f25
14 is good
Specializing In Breaking Things Professionally
15486372<-----
Old 02-24-2019, 06:07 PM
One more update. I checked the sunroof drain holes and they all appear to be draining correctly. Front holes drain in the front door pillars and the rear drain somewhere in the rear wheel well. I still have not been able to locate the hoses in the rear wheel well or behind the fuse box in the trunk. In either case, they appear to drain fine.
A few weeks ago I did find a ton of water in the battery compartment. I still think the Trunk Louver Vent - which is above the battery - is leaking. When I pour water on the rear windshield I can see water flow behind the vent. How does it come off?
Lastly, with all the water problems this car has I'm thinking of installing some water sensor alarms in the battery compartment, spare wheel well, and possibly under carpet on front passenger side. A set of 3 "dumb" alarms is less tan $20 and seems like a worthwhile investment. Haven't seen this mentioned but what do you think? example at Amazon
Old 02-25-2019, 03:29 AM
Doug Huffman's Avatar
Nuclear engineer
I bought a six pack of water alarms but the squeaker is not loud enough and of too high a frequency for me to hear.
I looked at your AmaXon link and saw mention of "high frequency" and read the product 'specifications' to NOT see a frequency adjustment.
Similar Threads
starting issue mattmar1 E39 (1997 - 2003) 9 09-19-2018 02:12 PM
Intermittent Starting / Ground Strap bbrantley911 X5 E70 (2007 - 2013) 8 09-17-2018 11:02 AM
Please Help - Starting Issue gregwake X3 E83 (2004 - 2010) 2 08-02-2018 04:41 PM
n54 Warm Starting Issue Lowsinthe20s E90/E91/E92/E93 (2006 - 2013) 42 03-25-2018 05:32 AM
