Dual Zone Climate Temp Issue - Bimmerfest - BMW Forums
Old 02-27-2019, 01:37 PM
E60Ag E60Ag is offline
Mein Auto: 2006 550i 6MT
Noticed the passenger side air vents are blowing warmer air than the driver side even though both sides are set to the same temp. However, if I turn the temp settings to the coldest setting, both sides seem to sync up but if I turn the temp to 70 for example, the driver side will work normally but the passenger side will blow hot and stay that way.
Don't have a lot of experience with dual zone systems so I'm looking for a little guidance on where to start the diagnosis.
Old 02-27-2019, 01:58 PM
MysticRob MysticRob is offline
Mein Auto: E61 535xi Deep Sea Blue
Read the owner's manual to ensure you haven't overlooked anything specific to your car, like the individual iDrive HVAC settings, etc.
2008 535xi E61 Touring Wagon / 110k Miles / Deep Sea Blue Exterior / Natural Brown Leather Interior / MHD Stage 1 91 Octane Tune / xHP Stage 1 Transmission Tune / xHP xDelete
Old 02-27-2019, 02:30 PM
Did that this morning, settings are all squared away. Is there a "common" issue with these systems? Like a temp sensor or a blend door actuator going wonky?
Old 02-28-2019, 05:40 AM
Jtbgonesailing Jtbgonesailing is offline
Mein Auto: 05 530i & 81 320i
You really need to pull the error codes on the IHKA module, anything less is just guessing.
Old 02-28-2019, 08:03 AM
I figured I'd end up having codes pulled but hoped there'd be a more common issue that I could use as a jumping off point.
Appreciate the help!
Old 02-28-2019, 09:28 AM
NoQuarter's Avatar
NoQuarter NoQuarter is offline
Mein Auto: 2008 535xi
I am not aware of any common issue to point you to for this one unfortunately
Old 02-28-2019, 11:24 AM
zoom750 zoom750 is offline
Mein Auto:
Heater valve is a known issue.
https://www.pelicanparts.com/techart...eplacement.htm
Old 03-01-2019, 07:36 AM
Replaced that valve last year. Heater works well when the iDrive and temp dials are set to hot, it's just when I turn the dials (and the iDrive settings) back to cooler temps, the passenger side either stays hot or will SLOWLY cool off but won't match the air temp coming out of the driver's side. Off to the indy next week for codes.
Similar Threads
E65 V12 debuts nate General BMW Questions 22 06-09-2016 12:44 AM
My climate control is wierding me out... tommyd 3 Series & 4 Series 11 08-27-2003 06:25 AM
Auto Climate Control + Defog Button = Melted Hair!? OBS3SSION 3 Series & 4 Series 16 03-31-2003 11:31 AM
Dual climate control on 04 models?? bmw325 3 Series & 4 Series 18 01-09-2003 12:31 PM
Basic climate control question... bmw325 3 Series & 4 Series 7 03-12-2002 08:12 AM
