How do I Reprogram my Key to open my doors - Page 5 - Bimmerfest - BMW Forums
Old 05-21-2020, 03:18 AM
u.nanimous u.nanimous is offline
Certifiable BMW Whackjob!
Mein Auto: 1999 740iS, 2008 335xi
Originally Posted by rpaitich View Post
mattmar and 528i,
The transponder is a passive component; to program it a complicated factory device is needed.
My plan was to remove the transponder from the old key (works for starting engine, but not for doors) and install it in the new key (works for doors but not for starting engine).
The dealer wants USD$250 to program a factory key. I bought mine online for $15, but the transponder needs programming to allow it to start the engine. A local lock shop will do it for $200.
My new $15 key works fine for locking/unlocking the doors, and my old key works fine for starting the engine. I may simply carry both keys; not an elegant solution, but will work.
Thanks for your suggestions,
Ron
The programmed part of the transponder is not passive, it gets powered by the antennae ring when put in the ignition - RFID.
I see a couple of your posts about making the new key start the car, what about making the old key remote functions work?
Another option would be get a valet key from the dealer.
Posted through Tapatalk downloaded to my neural implant
2005 Venture Extended LT - what else you gonna drive when you have 6 kids, cargo and still want better than 10MPG
1999 740iA - long term project/summer DD
2000 Impala LS - RIP 12/23/2016, officially totaled by insurance company
2001 330xiA - fXtXeX/son project - now April's car
2008 335xiA - winterbeater Impala replacement
2002 530i/5 - 2.5 years searching...and it is John's car
1989 535i/5 - the spare car
2002 325xiA - to be Charlotte's when she gets her license (?2019?)
Old 05-21-2020, 06:53 AM
theWalkinator theWalkinator is offline
Mein Auto: 2002 BMW 540iA
AK-90 is only about $40 on eBay or Amazon, remove your EWS which is under the driver side dash, program the key with AK-90 is quite easy and you can get more keys cut and programed, just search youtube, there are many videos demonstrating how to program BMW keys, I have done 2 keys, replaced battery on my original keys now I have 3 working master keys.
Old 05-21-2020, 08:35 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
I'd appreciate it if one of you can take a picture and show me where the transponder is.
Thanks,
Ron
On the 9/99 build date-up remote key...it is the new style and the EWS trasnponder is soldered to the IC board inside the key. The older style remote key's EWS transponder is on an embeded chip that can be easily transferred...as well as the non remote keys (transponder is an embedded chip).
If you're new remote key purchased online was a blank key blade and has a body/case that can be opened...as someone mentioned...you could purchase one of the inexpensive (plastic head and key blade) valet keys using your VIN to have it ordered...then remove it's EWS transponder and place inside the body case of your new online remote key. That would be much easier (and 99.9% successful) versus trying to desolder the transponder off your existing remote key and resolder it onto your new remote key.
The transponder chip inside the old style remote and all the non remote keys looks like the one in the pic below...it can be removed and inserted into another key much more easily:
{the small highlighted rectangle shows the location of the EWS transponder inside the keys below}
ID:	893367   Click image for larger version
ID:	893369   Click image for larger version
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 05-21-2020, 10:21 AM
rpaitich rpaitich is offline
Mein Auto: 2002 540i, 6-speed
AK-90 programmer
Thanks for the tip; I found one on Amazon for $30!
How can dealers justify charging $200 to program a key?
Old 05-21-2020, 01:23 PM
QSilver7's Avatar
They don't actually "program" the key at the local dealership. You get a new remote key (or regular key) with the blade cut correctly (based on your VIN) and a transponder chip programmed with your car's ISN (again, based on the VIN as the car came off the assembly line). They new key will have the next identification number in line that will be one of the original 10 that was programmed into your EWS control module...when it came off the assembly line.
The local dealership doesn't program the key...they order it (based on your VIN) from a regional or national BMW center/HQ...which then sends it to the dealer...which then sells it to you. $$$
Take note of the paragraph titled FIRST TIME INITIALIZATION AT THE PRODUCTION PLANT in the BMW info below:
(SOLD)
Similar Threads
Z3 Transponder Key replacement hassle jameswbl E36/7 Z3 (1996-2002) 4 07-27-2009 03:03 PM
Key wont turn, car thinks its running BMWredneck E36 (1991 - 1999) 3 08-13-2006 06:25 PM
Can the key open all windows with one touch? KevinH General BMW Questions 6 01-23-2006 11:15 AM
Help! Key Memory & seats binaryfarms 3 Series & 4 Series 11 03-23-2003 01:32 PM
