535xi - Bimmerfest - BMW Forums
Old 05-27-2020, 11:24 AM
Mavrick65 Mavrick65 is offline
Mein Auto: 535xi 2008
535xi
Hi I have 535xi 2008 and I have issue when I accelerate hard my car goes to safe mode.
Can anyone advice please what possibly is the issue thank you. If I restart the car the issue is gone.
Old 05-27-2020, 12:52 PM
habbyguy habbyguy is offline
Mein Auto: 2006 530xiT
You need to read the codes. We could narrow it down to a few hundred things you should look for with the information we have now...
Old 05-27-2020, 01:34 PM
Unfortunately i don't have diagnostic tool that will read that codes. I was told that most likely turbos are the issue, the car has 161,000 and i have since turn 90,000. I can still drive but can't accelerate fast.
Old 05-27-2020, 02:17 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
You will need to take it somewhere that can.
I don't understand the 161000 and 90000.
Old 05-27-2020, 02:37 PM
fjord fjord is offline
Mein Auto: '10 535i,2x '07 530xi wgn
The codes...you must find someone to read them so we can help.
Old 05-27-2020, 05:43 PM
Ok i will try to find it thanks.
Old 05-27-2020, 09:24 PM
kd7iwp kd7iwp is offline
Mein Auto: 2001 325i
I'm guessing it's a 30FF code from failing wastegates.
Old 05-28-2020, 03:55 AM
mtnbimmer mtnbimmer is offline
Mein Auto: 325ix, 530xi
That's right, your guessing. Until we get the codes, we don't know much of anything.
Old 05-28-2020, 06:46 AM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
Could be as simple as a misfire. Or...
Old 05-28-2020, 07:58 AM
plus1111 plus1111 is offline
You will almost always get a turbo deactivation code when something goes wonky. Ours did the same thing a while back and I checked vacuum lines, pulled the plugs for a look, basic stuff. Put it back together and the issue disappeared. A few months later was having a misfire. Found a leaking injector. Replaced with a used one of the same index. A month after that another one got leaky. I replaced all 6 with used ones of a higher index. No more issues. (Can't afford new injectors right now.)
Hobby mechanic doing my own work for 50 years or so.
We have a 2006 530xi Touring and a 2008 535xi sedan.
I can't really remember the last time I took a car to a repair service.
Old 05-28-2020, 08:36 AM
zoom750 zoom750 is offline
Mein Auto:
In the meantime, you can try checking your charge pipe to see if it has separated from the throttle body, or if it has cracked. Any leak there would cause that error.
Old 05-28-2020, 11:30 AM
MysticRob MysticRob is offline
Mein Auto: E61 535xi Deep Sea Blue
Easy fix, just don't accelerate hard.
Make sure whatever code reader you use is set up to read BMW-specific codes.
Most likely issues are vacuum hoses, spark plugs, coils, injectors, or valves needing walnut blasting.
Hopefully you do your own maintenance. If not, run away. Fast.
2008 535xi E61 Touring Wagon / 110k Miles / Deep Sea Blue Exterior / Natural Brown Leather Interior / MHD Stage 1 91 Octane Tune / xHP Stage 1 Transmission Tune / xHP xDelete
Old 05-28-2020, 01:56 PM
Kurt_ Kurt_ is online now
Mein Auto: 2008 535xit
30FF is just a generic "I went into safe mode" code, it doesn't really mean anything.
Before you go spending money, check all the vaccuum lines. Most importantly, make sure one hasn't popped off a wastegate. I had one fall off and it only underboosted during harder acceleration. During city driving, it did fine on a single turbo and an open hose.
I didn't even realize it because the wastegates are tucked away.
It's a simple fix if it's a vaccuum line. Start there. Marky mark covered the other common causes.
Old 06-02-2020, 05:01 PM
RAZ1777 RAZ1777 is offline
Mein Auto: 540i Sport 6 speed
I've got the same problem. Just started at 118,000 miles. Now I usually get code 140011 (Misfiring: Injection cut) under hard acceleration, but not with easy acceleration. I changed the valve cover gasket and it was OK for the first few hundred miles. Plugs done 20K miles ago. No injectors yet.
