how to turn off Parked-car ventilation - Bimmerfest - BMW Forums
Old 05-28-2020, 08:43 AM
Joze 48 Joze 48 is offline
Mein Auto:
My 2002 525 suddenly developed an issue where the parked-car ventilation fan is running and the entire ac system is unable to be engaged, no lights on the ac. I tried disconnecting and reconnecting the battery,no luck.
I am unable to reset or turn off the parked-car ventilation because the many of the radio display and dashboard display lights are burned out.
Two questions ;
1. How can I shut off the parked-car ventilation?
2. How can I replace the radio and dash lights?
Old 05-28-2020, 10:16 AM
toybreaker toybreaker is offline
Resident Curmudgeon
Mein Auto: 2000 540i6
radio and dash lights.... fixels on facebook...
ventilation.... No clue.
Old 05-28-2020, 11:07 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Sounds like the IHKA panel is busted. This is the control panel for HVAC.
The MID is just a display device for the radio, et al.
The only thing at this point is to disconnect the battery until the IHKA is fixed/replaced.
When you say "dashboard display," do you mean the main instrument cluster, where the speedo resides?
Old 05-28-2020, 12:18 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: M550i, 540M-Sport, Scud
If the HVAC is running with key out of the ignition, could be the FSU/FSR (final stage resistor/unit) has failed. Search here "FSU" for more info.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, Eibach front and rear anti-roll bars, M5 rear traction rods, H&R 15mm wheel spacers, ST X (KW) coilovers, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, Zimmerman rotors, Dinan Stage 1 software, USA Spec Ipod/Iphone integration.
Old 05-28-2020, 03:31 PM
Good point, but he specifically referenced the Parked Car Ventilation, unless he was confused.
Old 05-28-2020, 03:34 PM
528iAut 528iAut is offline
Mein Auto: 1996 528i
Hmm, does that not normally only work when "rest" is pushed? Is anything programmed on the MID?
https://www.bimmerfest.com/forums/sh...d.php?t=476830
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 05-28-2020, 04:04 PM
I've never used it, but, yes this function is accessed via the MID. REST is an IHKA function.
Old 05-29-2020, 08:28 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
Ditto edjack...but if you have the LOW MID...this feature may be foreign to you since it requires the HIGH MID. The immediate venting & timed event venting is a function of the HIGH OBC which is set-up and turned off/on using the TIME button on the MID (or Nav). Plus, the REST (residual heat) feature only works in cooler weather...the ambient temp must be below 59 F and it uses the residual heat from the engine to blow warm air into the cabin. In warm weather...the MID's/NAV's parked ventilation feature blows ambient temp air into the cabin to keep it from becoming an oven. See the info below about PARKED CAR VENTILATION.
The thing is though...the ignition has to be in KL R (the 1st ignition position) to initiate the immediate venting session...but I'm can't remember off hand if you can set a timed event in any ignition position. But if it is set...the red LED on the MID illuminates to let you know that there's a timed event set-up (or is running).
If none of that has occured...and the IHKA blower is running...I'm more inclined to think the FSR/FSU is on the fritz...especially since its' running with the car off and the OP says they can't control the fan.
ID:	894541   Click image for larger version
Name:	E38%20E39%20E53%20Service%20Station%20and%20Parked%20Car%20Ventilation%20Features%20Explained.jpg
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Old 05-29-2020, 09:33 AM
Thanks. My owner's manual only offers a scant description; "the exercise is left to the owner."
Old 05-29-2020, 09:38 AM
Mein Auto:
Thanks all! i am replacing the blower motor resistor.
Old 05-29-2020, 10:06 AM
IIRC, Valeo or Hella are the ones to get. Ebay offbrand units are poorly made. That's one reason that they are so cheap.
If you DO buy one for less than $100, get two, as you'll be replacing them frequently.
BTW, these devices are not resistors, but have a power transistor that controls the blower, based on a control signal from the IHKA panel.
Old 05-29-2020, 12:02 PM
You can get them for less than $50, and it will be the latest factory BMW part, most reliable (most recent update), and with a lifetime warranty:
Correct one is the Sitronic/Valeo which is the OEM BMW one sold at the dealer.
It is sold under private label by REIN, for less than $50 at FCP Euro. FCP Euro also offers a lifetime warranty on everything they sell.
https://www.fcpeuro.com/products/bmw...m-64116920365b
Old 05-29-2020, 01:13 PM
Lifetime warranties are good, but one still must do the replacement (or have it done).
Old 05-29-2020, 03:40 PM
Agreed, but the combination of the most reliable part being the factory oem BMW one, back with a lifetime warranty is as good as it gets with the FSR/FSU. The latest version seems to be solid.
Old 05-29-2020, 05:01 PM
Wow! That IS cheap.
Old 06-01-2020, 01:05 PM
Mein Auto:
Ed, i changed the resistor but the blower fan still kicks in with the key off as soon as I reconnect the battery. my pixel are shot so I am unable to shut off the parked car feature via the OBC. any suggestions?
Old 06-01-2020, 02:40 PM
I'm flummoxed.
There may be a BMW-specific scan tool that can shut it off. Otherwise, you'll need to get the display pixels fixed.
