2001 X5 E53 - Transmission Warning Light - Hard Downshift - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 08-09-2018, 12:59 PM
mpouliot mpouliot is offline
Mein Auto:
Hello, First timer here.
My 2001 X5 E53 3.0 has 160K miles and has run great since this week.
Battery died due to bad alternator. Replaced alternator and immediately after, the transmission warning light came on, even though the car hasn't been driven again yet.
I took it for a spin around the block and it up-shifts fine, but when I slow down to a crawl, it downshifts hard (last 2 gears), like the TC is banging slightly.
I went to Auto Zone (2 blocks away) I had it tested on AutoZone's diagnostic tool...(I know, not the best) and NO CODES came up.
I don't want to take it out on the road like this...could I have damaged a TCC Solenoid somehow while replacing the alternator? I don't know how but it's seems fishy that this happened immediately after replacing it.
Also, the new alternator must have a bad VR as it is severely overcharging (18v-19v)
Could that affect the tranny in anyway?
Frustrated, please help!!!
Old 08-09-2018, 01:04 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
Have the codes read.
Old 08-09-2018, 01:56 PM
Mein Auto:
No Codes, but i had it read at Auto Zone around the corner (i know, not the best)
The Tranny Light (gear w/exclamation) is on, it should throw a code, right?
Old 08-09-2018, 02:16 PM
If it is showing a warning light it should be throwing codes. If you're going to keep this truck I recommend buying a scanner. Either the Foxwell or the Schwaben (same scanner). They were about $175 last time I looked. They're invaluable if you're going to DIY on your truck. Otherwise, find a local shop that specializes in BMW and have them read your codes.
Old 08-09-2018, 03:06 PM
Mein Auto:
Still wondering if an overcharging alternator could cause transmission issues like the hard downshifting?
Old 08-09-2018, 03:22 PM
Possible. It will cause a bunch of other problems too like destroying your battery. Get a replacement.
Old 05-13-2020, 07:53 PM
BurbBimmer BurbBimmer is offline
Mein Auto: 1987 325i Cabriolet
X5 E53 Transmission Fault indicator light
I had a similar experience. After the light came on, I tried the reset using the gas pedal, etc. Engine off, then back on, etc. I could drive in manual or Automatic, but experienced hard shifting. I read somewhere to check fuse #5 in the glovebox. I did, it was fine, had it out for about a minute. put it back in, started the car, and everything was back to normal.
Old 05-25-2020, 08:21 AM
X54life84 X54life84 is offline
Mein Auto:
Personally for me I ain't an expert. I have rebuilt my e53 transmission. It was a success. I wouldn't ignore that warning.i would check the fluid. I don't beleive on that BMW lifetime fluid bs. If you got a good scanner I would look at the input and output sensors on tranny. If you don't have a scanner. I would drop the pan at the tranny. Look for metals. From there you would know what next
Old 06-24-2020, 12:03 PM
Rmee4life Rmee4life is offline
Mein Auto:
I had Trans Fail Safe warning along with SES light on. Turned out to be MAF sensor
e53, e53 transmission, hard shifting, x5
