Enable Front-View Camera From R to D - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > G30 (2017 - Current)
The next generation 5 Series, chassis code G30, arrives at dealers in February 2017. Looking like a scaled down 7 Series and riding on the CLAR platform, the new 5 Series will have a focus on lightweight and sporty performance. Engines options will come from BMW's new B family for the 530 and 540 and a turbocharged V8 for the M550i. Read more about the 2017 5 Series
Old 03-23-2020, 04:12 PM
dvg6640 dvg6640 is offline
Mein Auto: 17' BMW 540i
I was recently in a Mercedes-Benz with the 360-degree camera and noticed that the front-view camera enables when the driver goes from Reverse to Drive. Does my 17' 540i with 360-degree have this feature? This would be very useful when parking in my garage as I have to maneuver the car through a very tight area to adjust the car 90-degrees. Thanks!
2017 BMW 540i Imperial Blue | Black Nappa | Driving Assistance/Plus/Plus II | Lux Seating | Premium | Sport Line | HK | Carplay
Old 03-24-2020, 12:26 AM
stevelup stevelup is offline
Mein Auto: G30 530e M-Sport
Yes, it does. I'm confused though - you already have the car? You must have seen it do this every time you ever moved from R to D?
Old 03-24-2020, 08:36 AM
DLF750's Avatar
DLF750 DLF750 is offline
Mein Auto: 2019 540iX
mine comes on when I get fairly close to something in front of me....
2019 540iX M Package, M Blue Brakes, bunch of other stuff...
Old 03-24-2020, 09:48 AM
LogicalApex LogicalApex is online now
Mein Auto: 2020 530xe
Yeah it should enable under either of these four scenarios:
  1. When getting very close to an object picked up by the car's radar (either while parking or driving at slow speeds like in traffic)
  2. When switching from R to D
  3. When manually pressing camera button to the left of shifter while in D
  4. When a GPS "activation point" is encountered while in D
Old 03-24-2020, 01:10 PM
Maybe I should add a GPS Activation Point. At this time, when I switch from R to D, the rear-view camera is still shown.
Old 03-24-2020, 03:54 PM
You can also tap the camera button if you want to force it.
I use the GPS activation point for the corner of my street since visibility is very poor there and there is a crash a few times a year, at least, so it adds a second set of sensors (the cross traffic alert also activates with the front camera). But I haven't tested how well GPS activation works when dealing with a parking situation. Would be a lot easier to hit the camera button if I felt the need to shift it around.
I am not in the car right now (obviously lol), but I think you can also use the iDrive wheel to force pick the camera.
Also, one last thing. I think you need to have the camera set to "Auto" orientation to get it adjusting automatically. You can turn that off and in that case I don't think you'd see an automatic shift to the front camera in Drive. Like almost everything in a BMW you have some control.
Old 03-24-2020, 08:57 PM
For sure. I did find the automatic setting on my car (it's on the screen with the camera and an A) but it does not stay on that setting. I would have to tap on it every time I want the orientation to change depending on which gear I'm in. I'm going to see if there is a way I could code it in.
I definitely could just tap on it, but I would much rather have it done automatically for convenience.
Old 03-24-2020, 09:25 PM
There is a setting on my iDrive 7 version to make that the default. A similar setting exists in iDrive 6 I am sure.
Old 03-26-2020, 01:28 PM
Jack_88 Jack_88 is offline
Mein Auto:
My front camera comes on when pulling out of too steep a drive. Also, the automatic braking engages backing out of some drives, thinking I'm about to crash. I had to turn off the automatic braking for reversing. The system is not perfect.
Old 03-30-2020, 12:10 PM
I am working with a variety of teams to determine if this can be coded in. I do think there should be a way to do so... I have gone ahead and set waypoints but they don't work too well in my driveway as they tend to not activate.
